what does it sound like the problem is...
Old Apr 29, 2003 | 07:11 PM
Grengostarr's Avatar
Default what does it sound like the problem is...
im djheat1200....
what does it sound like my problem is...ius it my clutch or tranny or whaaat??? help me please!!!
SirBiKeAlOt16: hey r u still looking for a clutch for your gsr?
DjHeat1200: hey, umm it depends.....
DjHeat1200: i have an centerforce stage 2 for 340.......
DjHeat1200: if you can beat that then yea
SirBiKeAlOt16: well i got one it was for my car but i found out the prob was not my clutch so i have no use forit
DjHeat1200: what was your problem then
SirBiKeAlOt16: i got a exedy oem replacement going for hella cheap
DjHeat1200: cuz mine is fucked up...
SirBiKeAlOt16: i need a whole new tranny
DjHeat1200: and im not positive its the clutch......
DjHeat1200: what is it doing
SirBiKeAlOt16: whats yours do
DjHeat1200: well...i can have the car off
SirBiKeAlOt16: ya
DjHeat1200: and shift into every gear fine
DjHeat1200: then turn the car on when its in neutral
DjHeat1200: and press the clutch in....and it wont go into any gears....
DjHeat1200: i can force them and they grind..
DjHeat1200: but thats dumb
DjHeat1200: and i can turn the car off...
DjHeat1200: and put it into first gear
DjHeat1200: then turn it on
DjHeat1200: and i can have the clutch all the way in
DjHeat1200: and it will still jump like its not fully engaging
DjHeat1200: ....
DjHeat1200: and it does this on and off
DjHeat1200: like it was fine all day and then it started doing it again
SirBiKeAlOt16: ic
DjHeat1200: and i changed the fluids...so its not that
SirBiKeAlOt16: try to get a friend or someone that knows clutches and trannys
DjHeat1200: i think im going to post up this im
SirBiKeAlOt16: cause just to install a clutch is like 250 and up on just labor
DjHeat1200: nah, i know a buddy that is going to put it in if i buy him dinner
SirBiKeAlOt16: thats y i had the mechanic drive my car
SirBiKeAlOt16: lol
SirBiKeAlOt16: thats not bad
DjHeat1200: haha, nah
Old Apr 29, 2003 | 07:34 PM
Default Re: what does it sound like the problem is... (Grengostarr)
bump before i go to bed.....please help me guys........
Old Apr 29, 2003 | 07:44 PM
Mohudsolo's Avatar
The clutch is not disengaging properly. Did you try to flush out and bleed the clutch fluid? If so, then the throwout bearing or pressure plate are worn and using up part of the throwout arm travel and not enough left to properly disengage the clutch. Also make sure nothing like a floor mat or carpet are keeping the pedal from going down all the way. Yes, I fixed someone's clutch by throwing away the floor mat.
Old Apr 30, 2003 | 08:13 AM
you are a genius...and no its not the floormat, but your right about the arm travel...the new clutch is on the way...thanks
TigerLy
Jul 16, 2008 01:59 PM
GoKOOLjeff
Nov 5, 2006 09:01 PM
chris408
Oct 22, 2003 03:13 AM
turbochic
Jul 14, 2003 07:28 PM
