Spring ??'s
Old Aug 5, 2003 | 05:28 AM
IntegrasGoFast's Avatar
Default Spring ??'s
I am looking into putting some H&R Race springs on my integra ya'll prolly already know that this lowers 2.0 in f and 1.75 in r i was wondering if i was going to need any kind of camber correction or anything like that?
Also let me know if ya'll have any better springs to rccomend instead of the H&R for just daily street driving that will help out the performance a little bit
thanks
Old Aug 5, 2003 | 06:10 AM
acuraholic's Avatar
Default Re: Spring ??'s (IntegrasGoFast)
You might be able to get away without a camber kit. Toe will chew up tires a lot quicker than negative camber will, so make sure you get an alignment and rotate often. H&R Race are pretty stiff/low for everyday street use IMO. If your roads aren't that bad it might be alright for you. Maybe look into something height adjustable just in case.
Old Aug 5, 2003 | 08:33 AM
Default Re: Spring ??'s (acuraholic)
Yeah the roads here are pretty good so i don't have much to worry about there. i've just hear like 18 diff versions about whether or not i am going to need camber adjustment i guess ill just go without it and if it turns out bad then well hey i can get some new tires!! thanx for the help
Old Aug 5, 2003 | 09:56 AM
lustedp's Avatar
man i dont buy that stiff springs arent good with bad roads...this weekend i drove through some of the worst roads in the area and it was fine, hill were fine, steep driveways, fine
higher rates imo are better so u dont bottom out at a bump as much
2.0" drop generally will require a camber kit
get a lifetime alignment from firestone if you can and post your numbers...also realize that after a while your alignment will be different from when u got it
nismo350z
Jun 13, 2006 04:42 PM
silva95teg
Jul 24, 2005 12:04 PM
dOwNeR
Aug 21, 2004 09:03 PM
CoxhEd
Jun 10, 2004 09:49 PM
pmachan
May 5, 2002 08:46 PM
