I got an idle problem... HELP!!!!
Old Aug 6, 2003 | 07:11 PM
leira619's Avatar
Default I got an idle problem... HELP!!!!
I recently had a skunk2 intake manifold and a big bore throttle body (70mm) installed. Now, when I drive and I'm coming to a stop and place my car in neutral, my car will idle anywhere from 1500-2100 rpms. Then, it got really bad and started to go from 2000 rpms to 1100 rpms and kept fluctuating. I had a shop take a look at it and had my Idle Control Valve replaced. Now, when I start up my car, it idles around 450 rpms or less.... almost to the point where it's gonna stall. Also, when I drive, come to stop and put my car in neutral, the car still idles around 1100 rpms. It seems like I've lost a lot of low end torque on my 96 GSR. Any advice would be helpful
Old Aug 6, 2003 | 07:15 PM
Loveless's Avatar
Default Re: I got an idle problem... HELP!!!! (leira619)
you could have gotten a faulty iacv, why don't you swap it back and see if the problems goes back
if it doesn't work then try to adust the idle speed
dices543
13
Nov 19, 2010 04:07 AM
bb4 jdm lude
Mar 12, 2008 09:25 AM
GetawayInMoscow
May 3, 2006 03:02 PM
One2chi
Jul 9, 2005 02:05 PM
b16crx88
Mar 19, 2005 11:14 AM
