problem with breaks
Old Aug 6, 2003 | 06:20 PM
Dc2 Powered's Avatar
Default problem with breaks
i just had the break oil changed and the breaks cleaned and stuff and it still sweeks why is that?.. do i need new breaks?
p.s those idiots messing with the admins are morons.. sad how some people have no lifes.. plz don't think i am one of those guys..
Old Aug 6, 2003 | 07:55 PM
Brian_TII's Avatar
Default Re: problem with breaks (kRaZiE TegZ)
Brake squeal is typically caused by one of the following:
1) Your pads are worn out and they are rubbing on the wear indicator
2) The brand of pads that you are using just happen to squeal more than most
3) Your pads were installed without the proper shims / anti-squeal goo
Bleading the brakes will not resolve brake squeal, and spraying the pads / rotors down with brake cleaner typically won't either. Your brakes may just squeal... I assume whoever bled them probably looked @ reason #1...
Old Aug 6, 2003 | 08:10 PM
i'll check into that thx alot bro
mickey513
Nov 16, 2018 03:56 PM
lude1888
Jul 3, 2006 08:59 AM
YodajdmEK4
Jul 23, 2005 05:33 PM
Feuerraeder
Oct 17, 2003 11:42 AM
integra0260
Oct 21, 2001 08:09 AM
