FPR problem
Old Aug 5, 2003 | 11:29 AM
hpb17a's Avatar
Default FPR problem
I just put the B&M FPR and guage on my car, and when I remove and plug the vaccum line to the FPR, the fuel pressure needle will just bounce around whatever value I set it to, (Same results with the line plugged in and I pull the throttle cable to WOT) Correct me if I'm wrong, but shouldnt the needle go up a few lbs. When the vaccum line is pinched? The car runs, it is a little hard to start when it is cold though, and it doesn't seem to have the pull up top that it used to. Any suggestions? Thanks.
p.s. I tried searching
Old Aug 5, 2003 | 11:39 AM
tilt's Avatar
Default Re: FPR problem (hpb17a)
Sorry, but I had a hard time understanding what you are trying to say.
If you take the vacuum hose off, the gauge should jump about 10psi. You should adjust the fpr with the vacuum hose off. In other words if you want 40psi, set it to 50 when the hose is off.
Old Aug 5, 2003 | 12:43 PM
hpb17a's Avatar
Default Re: FPR problem (tilt)
That's the problem, If i disconnect the vaccum hose, the pressure doesn't jump anywhere, it just sticks to whatever value it's set at with the line on. e.g If I set it at 45 with the line on, and I take the line off, it's still 45. and vice versa.
B16b-EJ8
Oct 25, 2006 03:28 PM
Louie_EM1
12
Feb 27, 2005 11:16 AM
typeeg
Jun 16, 2004 07:01 PM
Popkorn
Nov 25, 2002 11:43 PM
Greyout
May 26, 2002 05:13 PM
