ABS code
Old Aug 4, 2003 | 06:04 AM
meat's Avatar
Default ABS code
Anyone know what the ABS code 44 is on a '96 GSR? I have seen the codes for '98-'01, but not for a '96.
Thanks
Old Aug 5, 2003 | 06:07 AM
meat's Avatar
Default Re: ABS code (meat)
TTT
Old Aug 5, 2003 | 08:03 AM
JimBlake's Avatar
wheel sensor - right rear
Old Aug 5, 2003 | 09:57 AM
meat's Avatar
Default Re: ABS code (JimBlake)
Do you have a link to the codes or are you looking at a manual?
Thanks
Old Aug 5, 2003 | 10:57 AM
JimBlake's Avatar
I got this list from my Helm manual ('95) & for some reason I typed it into a text file that I have here...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Old Aug 5, 2003 | 11:41 AM
meat's Avatar
Thanks for the info.
jdm201010
Apr 18, 2014 12:08 PM
tapwc19
May 31, 2009 06:01 PM
JimBlake
Nov 23, 2005 04:58 AM
scott kane
Apr 6, 2004 11:38 PM
moepeppa
Sep 15, 2003 03:22 PM
