Weird car behavior
Old Jan 19, 2004 | 03:45 PM
Ldc4S's Avatar
Default Weird car behavior
for the past couple of weeks i noticed sometimes when im sitting at a stoplight..my car seems to rev up rpms then goes down then goes up then goes down and so on...what could this be?? yea im a newbie so dont be too harsh
Old Jan 19, 2004 | 03:55 PM
revhigh89's Avatar
Default Re: Weird car behavior (90teg04)
maybe a loose hose or a leak somewhere, check the hoses
Old Jan 19, 2004 | 04:28 PM
Ldc4S's Avatar
Default Re: Weird car behavior (evilryu530)
i checked the hoses and theres no leaks i cant seem to find out wut it is
Old Jan 19, 2004 | 04:48 PM
Ldc4S's Avatar
ne body else have ne ideas??
Old Jan 19, 2004 | 04:53 PM
Chris1091's Avatar
IACV?
Old Jan 19, 2004 | 05:13 PM
kmk16O5
Guest
Posts: n/a
you have a bad map sensor it sounds like. my car was just doing that, replaced the map sensor, problem fixed.
Old Jan 19, 2004 | 05:27 PM
Ldc4S's Avatar
Default Re: (kmk16O5)
oh ok thanx i'll check into that
Old Jan 19, 2004 | 06:08 PM
florduhdude's Avatar
Default Re: (90teg04)
Try cleaning the throttle body and readjusting the idle first. It sounds like the idle adjustment screw is open too much. Usually the symptoms of this appear after you clean the throttle body.
Old Jan 19, 2004 | 06:56 PM
dc2inms's Avatar
Default Re: (florduhdude)
vacuum leak
Old Jan 19, 2004 | 07:02 PM
mr.beeks's Avatar
Default Re: (dc2inms)
there is no map sensor for this integras.
it is simple just clean the
cold idle control valve
located in the intake manifold
just follow the two hoses that come out of the front hose
to the intake manifold you will find a cylinder
take the two screws out clean inside and put back together.
Old Jan 25, 2004 | 06:11 AM
b18c1_powered_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kmk16O5 &raquo;</TD></TR><TR><TD CLASS="quote">you have a bad map sensor it sounds like. my car was just doing that, replaced the map sensor, problem fixed.</TD></TR></TABLE>
buckwheaT!!!!
ason fishfuck with a new user id "KMK1605" doesn't change anything. once a crook always a crook.
https://honda-tech.com/zerothread?id=678900
https://honda-tech.com/zerothread?id=670626
https://honda-tech.com/zerothread?id=659242
https://honda-tech.com/zerothread?id=678905
https://honda-tech.com/zerothread?id=659490
Old Jan 25, 2004 | 08:33 AM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by florduhdude &raquo;</TD></TR><TR><TD CLASS="quote">Try cleaning the throttle body and readjusting the idle first. It sounds like the idle adjustment screw is open too much. Usually the symptoms of this appear after you clean the throttle body.</TD></TR></TABLE>
this is good for the initial. try pulling your plugs and check them for discrepancies. anychance you had minor hydrolock. also check your compression.
elli
Jun 1, 2010 01:22 PM
crfr230
Apr 24, 2007 07:48 PM
19992civichatch
Mar 15, 2007 07:33 PM
mikeunreal
Oct 26, 2005 05:31 PM
GaRn
May 20, 2004 09:29 AM
