ECU reset?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS »</TD></TR><TR><TD CLASS="quote">Disconnecting the neg battery terminal will reset some things. Or there is a button under the dash somewhere that will reset other things. Do a search for "ecu reset".</TD></TR></TABLE>
The button under the dash is for resetting the Maint Req light.
Another method of resetting the ECU is to pull the 15A and 7.5A fuses from the fuse box. Let the car sit for a couple of minutes and then put back the fuses. Next turn back on the gar and let it idle for about 10-15 minutes, making sure all the accessories are off. Then turn the car off.
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Built »</TD></TR><TR><TD CLASS="quote">yup...just take out the 7.5 fuse out for 30sec. then everything will be reset</TD></TR></TABLE>
9civic8
Apr 2, 2004 08:51 AM
