Ground Control Question
Old Jan 20, 2004 | 11:32 PM
Toadfart's Avatar
Default Ground Control Question
I'm thinking about ordering a set of Ground Control Limited Edition for my 90 Teg. Spring rates are 350/280. I know a lot of you guys have higher spring rates, but I don't plan on auto-x'ing. Just spirited driving through town. Would these spring rates be ok for what I'm going to be doing? Or would some of you guys recommend higher rates?
I'm planning to mate them with Tokico Illuminas. Thanks in advance.
-Dan
Old Jan 21, 2004 | 01:09 AM
Mr. Choi's Avatar
New User
Default Re: Ground Control Question (Toadfart)
i think those rates are fine for a spin around town. personally i would go stiffer but thats jus me. im on 447 front and 335 rear with illumina's.
Old Jan 21, 2004 | 06:56 AM
rapid_roy's Avatar
That'snot to stiff, that is the neighborhood spring rate wise of the Eibach Prokit and the Comptech springs. That is about as stiff as I would go if you are not going to autox.
Cheers,
Sean
Old Jan 21, 2004 | 07:36 AM
nsxblueteg's Avatar
That is what I have on my integra and they are great for around town
Old Jan 21, 2004 | 07:40 AM
Boofster's Avatar
Default Re: (nsxblueteg)
That's the stock GC rate. I have the rear 280 springs if you want to buy them from me. I upgraded to 350/400. 100x better. You don't know what a real suspension feels like until you get something that doesn't bounce all over the place.
Rule of thumb is to go with a stiffer rear end. Also rear is what makes your ride feel different. Personally I think 280 is ridiculously low. Especially if you're going to drop your car 2"+ which your probably are. Get some Koni's too.
Old Jan 21, 2004 | 07:47 AM
Toadfart's Avatar
Default Re: (Boofster)
350/280 is bouncy? I'm not going to auto-x, but you are saying that 280 is too soft for the rear. Just in case, how much are you letting your stock GC's go for? Thanks.
Dan
Old Jan 21, 2004 | 07:49 AM
Toadfart's Avatar
Does it bounce on bumps or lean in turns? Are you on Illuminas as well? Thanks in advance.
Dan
Old Jan 21, 2004 | 09:01 AM
P1mpSlap's Avatar
Default Re: (Toadfart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toadfart &raquo;</TD></TR><TR><TD CLASS="quote">350/280 is bouncy? I'm not going to auto-x, but you are saying that 280 is too soft for the rear. Just in case, how much are you letting your stock GC's go for? Thanks.
Dan</TD></TR></TABLE>
IMO, 280 is way too soft for the rear. Go with at least 300 and you'll be fine.
Old Jan 21, 2004 | 09:12 AM
Toadfart's Avatar
Default Re: (P1mpSlap)
I kind of didn't want to spend extra for custom spring rates, but looks like I will have to. Getting 280 and setting shocks for stiffer rate wouldn't have the same effect? Thanks for the input.
Dan
Old Jan 21, 2004 | 09:15 AM
jonsteR's Avatar
You'll be fine with those rates. I had 350/250 and used it for street, autox and track.
Old Jan 21, 2004 | 09:19 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toadfart &raquo;</TD></TR><TR><TD CLASS="quote">I kind of didn't want to spend extra for custom spring rates, but looks like I will have to. Getting 280 and setting shocks for stiffer rate wouldn't have the same effect? Thanks for the input.
No, my H&R Sport springs are 276 lb/in all around, and it feels very uncontrolled over really rough roads, even w/ my Konis.
Old Jan 21, 2004 | 09:33 AM
dip-set's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
No, my H&R Sport springs are 276 lb/in all around, and it feels very uncontrolled over really rough roads, even w/ my Konis. </TD></TR></TABLE>
but how fast would one really go down a really rough road...i hope not fast at all..and on smooth pavement i bet it feels very controlled ...
Old Jan 21, 2004 | 09:35 AM
Community Builder
Default Re: (teg-your-it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">
but how fast would one really go down a really rough road...i hope not fast at all..and on smooth pavement i bet it feels very controlled ...</TD></TR></TABLE>
yeah well the roads are very bad here, including the part of the interstate that goes through here. There are MANY places where there are bad dips and bumps, and traffic is going 60-80mph, so what can you do? Unfortunately nothing but suck it up, or eventually get better suspension.
Modified by PatrickGSR94 at 5:52 PM 4/3/2004
Old Jan 21, 2004 | 09:47 AM
Toadfart's Avatar
So you actually would get higher rates even for daily driving?
Old Jan 21, 2004 | 09:57 AM
spd18's Avatar
i have GC's on the regular spring rate with neuspeed koni yellows. you say having a stiffer rear end is better? if stock rates are 350/280, and i just upgraded the rear, 350/400, would that improve my handling a lot? cant you just buy two rear 400 springs from eibach (who makes GC's springs) for pretty cheap? anybody know where to do this/how much it is?
Old Jan 21, 2004 | 09:59 AM
Community Builder
Default Re: (spd18)
Yes you can buy ERS springs in pairs, I think they are around $100/pair but I'm not sure. I'm also not sure what length of spring you should get, as they come in a wide range of lengths as well as spring rates.
I want stiffer springs so that my car doesn't pitch up and down so bad over dips and stuff, and also so it doesn't bottom out like the rear of my car has been doing.
Old Jan 21, 2004 | 10:42 AM
Toadfart's Avatar
Well custom rates it is. Thanks for the informative post as usual.
Dan
P.S. Know of a good place that has deals on GC's? Or do I have to go through GC direct?
Old Jan 21, 2004 | 11:10 AM
Jasper_db1's Avatar
those rates are fine for most people.
I'm on 550F/450R
Old Jan 21, 2004 | 11:20 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (Jasper_db1)
350/280 is fine for daily driving. If you're dumped, you will get a shitty ride no matter what your spring rates are, so I'm assuming you have more intelligence than that.
If you were an autocrosser or track racer, I'd say you should go with 375/450 or 425/550.
I'm currently on 380/450s with Koni Yellows... It's great...
Old Jan 21, 2004 | 11:25 AM
rapid_roy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">That's the stock GC rate. I have the rear 280 springs if you want to buy them from me. I upgraded to 350/400. 100x better. You don't know what a real suspension feels like until you get something that doesn't bounce all over the place.
The bounce has more to do with the struts/shocks/dampeners/whatever than with the spring. Actually, it's the relationship between the 2 more than any 1 factor.
That's more of a rule of thumb for tracked cars, stiffer rear ends on street cars that will be driven in the rain, snow, or by less than great drivers is a very bad idea. Throw in a rear swaybar and you have one dangerous combo for a car that never sees the track.
As a better rule of thumb, don't setup your car to promote oversteer if you don't know how to control it, or aren't driving where there are crash barriers.
280 isn't ridiculously low, I've got Comptech springs (up to 194 in the rear) and I am still chasing stock GSR's at the autox that have experience. Hardware is nothing, technique is everything.
Cheers,
Sean
Old Jan 21, 2004 | 11:43 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (rapid_roy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">Hardware is nothing, technique is everything.</TD></TR></TABLE>
Old Jan 21, 2004 | 12:13 PM
spd18's Avatar
i would see a good improvement with just upgrading the rear to 400? and the fronts are good like they are now?
where can you buy the springs at?
Old Jan 21, 2004 | 12:32 PM
locass316's Avatar
i had the exact setup with illuminas. I used to have skunks with 400F 300R on the illuminas as well, the handling was better but the ride wasent as smooth as the GC rates. IMO these are good rates for the street when they are paired up with the right shocks.
Old Jan 21, 2004 | 01:47 PM
Toadfart's Avatar
Default Re: (locass316)
You liked the ride with Illuminas and stock GC rates?
Old Jan 21, 2004 | 04:37 PM
onecleanDA's Avatar
i was thinking about getting the gc's for my da too. does anybody know the rates for the skunk2's? just wanted to compare.
