b18c1 problem
Old Jan 19, 2004 | 02:42 PM
lsvtec_teg's Avatar
Default b18c1 problem
i have a b18c1 motor in a 94 civic. scotts machine shop bored the motor 25over and put brand new itr pistons in and the head is milled because the head gasket blew before scotts machine shop. the motor is now in the car. when we crank it, it back fires and spuders, and the sparkplugs are wet with gas. the timing is right and we replaced the distributor, new plug wires, replaced injectors, changed map sensor. allso its runing a skunk2 intake manafold insted of a gsr one, with a p30 ecu. the ecu is only throwing a o2 sensor code, compression test says 125 on all cylnders........... please helpppppppp!
Old Jan 19, 2004 | 02:52 PM
oMek's Avatar
Default Re: b18c1 problem (lsvtec_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec_teg &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18c1 motor in a 94 civic. scotts machine shop bored the motor 25over and put brand new itr pistons in and the head is milled because the head gasket blew before scotts machine shop. the motor is now in the car. when we crank it, it back fires and spuders, and the sparkplugs are wet with gas. the timing is right and we replaced the distributor, new plug wires, replaced injectors, changed map sensor. allso its runing a skunk2 intake manafold insted of a gsr one, with a p30 ecu. the ecu is only throwing a o2 sensor code, compression test says 125 on all cylnders........... please helpppppppp!
only 125??? sounds like your losing comp somewhere, my gsr with 150k miles on it pulls 200 across all 4 and yours has higher CR pistons so....
Old Jan 19, 2004 | 03:16 PM
Havokmkr's Avatar
Popping and sputtering is an ignition problem. Those compression #'s are terrible. I have a 99 GS w/50k putting up 200+ across all 4 cylinders. If the plugs are that wet the timing probably isn't on. Try unbolting the distributor adjustment bolt and move it closer to the firewall or closer to the radiator until it idles a little better.
Old Jan 19, 2004 | 03:51 PM
IntegraB18's Avatar
Default Re: b18c1 problem (Havokmkr)
125 each cylinder?
Old Jan 19, 2004 | 05:42 PM
LSTEG96's Avatar
Default Re: b18c1 problem (IntegraB18)
ill take the tranny
young geezer
Sep 7, 2011 11:00 PM
mike1114
Dec 13, 2004 10:25 AM
ef-you
Sep 17, 2004 12:48 AM
lsvtec_teg
12
Jan 21, 2004 03:11 AM
zigs
Jun 21, 2003 04:15 PM
