Strut Question.....
Old Jan 22, 2004 | 07:54 AM
foxfai's Avatar
Default Strut Question.....
Hi, guys, I just bought a set of used struts on ebay to replace my older ones. Bought a 2000 LS set struts to replace my 94 LS and put a set of eibach to save money. The only question that i am having is the struts, should they be pushable by hand?? I ask the seller if those are blown and he said they aren't. Should the piston come back up after i pushed in???? I needed to know so i could get my money back.
Old Jan 22, 2004 | 08:08 AM
Creep's Avatar
Default Re: Strut Question..... (foxfai)
I've never tried pushing my stock ones in by hand, but
I know I couldn't when I tried with my konis.
Does the shaft return slowly?
when you say by hand, do you mean using the floor and
your body wheight, or do you mean actually holding the
shock body in one hand and using the other hand to compress?
Old Jan 22, 2004 | 09:18 AM
foxfai's Avatar
Default Re: Strut Question..... (Creep)
I push those in by hand.....very stiff and slow.....but i manage to get it all the way in with just my hand. The shock does not return at all. I am not sure if that's the way it suppose to be, but i could pull it out and very slowly. Please advise.
Old Jan 22, 2004 | 10:31 AM
foxfai's Avatar
BUMP??? Any info please.......???
rehaf
Suspension & Brakes
Aug 17, 2009 08:44 PM
b18c1ej8
Suspension & Brakes
Jul 18, 2007 09:46 AM
fe519
Nov 22, 2004 04:46 PM
94eg4
May 3, 2004 06:44 AM
integra99blue
Feb 6, 2002 08:45 AM
