o2 sensor question
Old Jan 19, 2004 | 09:09 PM
Vinhtran17's Avatar
Default o2 sensor question
Can anyone help me on how to check your o2 sensor to see if its fouling or anything..... because i seem to be wasteing alot of gas lately, even though i drive economicly...
anyway to check it? or how to reset it?
Old Jan 20, 2004 | 12:45 AM
TimoneX's Avatar
New User
Default Re: o2 sensor question (Vinhtran17)
You can test the sensor itself by measuring the resistance across it's leads. Should be 7-12ohms if memory serves, but it's been awhile. It's listed in the helms manual somewhere. If the resistance is infinite or 0 then you'll know you have a bad sensor.
Old Jan 20, 2004 | 04:26 AM
JimBlake's Avatar
Default Re: o2 sensor question (TimoneX)
You measure the resistance across the heater leads like TimoneX says, that's to check if the heater is OK.
To check the sensor itself, you can use a voltmeter on the signal wire, while the sensor is plugged in, & the engine warmed up & running. It should swing quickly back & forth from about 0.1 to 0.8 volts.
person
Honda CR-V & Element
Jan 30, 2016 05:25 PM
hondaaccord94
Mar 26, 2005 07:40 PM
Sinner
Jan 9, 2004 06:11 PM
BlackGSR87
Mar 7, 2003 08:45 AM
