motor mount inserts?
Old Jan 20, 2004 | 08:41 PM
inzaneN1's Avatar
From: INZANE FOR PRESIDENT 2008 .., las vegas nv, U.S.of.A
Default motor mount inserts?
Are integra motor mount inserts hard to install ? What do u need ? What are some good inserts ? Got prices and a web site? thx.
Old Jan 20, 2004 | 11:55 PM
sumyungguy's Avatar
Default Re: motor mount inserts? (inzane)
the energy suspension torque mount inserts ($30 ish) are very easy to install. just drop the motor slightly by using an impact gun on the two side main mounts take out the tourqe mount and zip tie the new ones in. but if your wanting to do the main mounts (i.e the liquid mount and the trannie mount) the front mount (luquid filled round silver thing on the driver side) is really messy and also makes the car no fun to daily drive, the car vibrates alote. and the trannie is just like the torque mounts and im not shure how much those run
Old Jan 21, 2004 | 02:35 AM
Toda Built's Avatar
Default Re: motor mount inserts? (sumyungguy)
in the sponser section the ES mount inserts are on sale for $36...its a great buy
Old Jan 21, 2004 | 02:56 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: motor mount inserts? (Toda Built)
i have them. they're easy to install. they're pretty much self explanatory, but if you're mechanically challenged they come with instructions as well.
basically, just put the motor mount inserts in the correct mount and zip tie that biatch to stay in place and you're set.
Old Jan 21, 2004 | 04:23 AM
RedTegLS's Avatar
Default Re: motor mount inserts? (AzntaggeR)
The two front mounts are not bad. The rear motor mount was a *****! Plus my car sits there at idle and the steering wheel, moonroof, A-pillar, pedals, and hood vibrate like a ****.
Old Jan 21, 2004 | 04:50 AM
ragejed's Avatar
Default Re: motor mount inserts? (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">The two front mounts are not bad. The rear motor mount was a *****! Plus my car sits there at idle and the steering wheel, moonroof, A-pillar, pedals, and hood vibrate like a ****. </TD></TR></TABLE>
Shouldnt install race parts in your car then
Old Jan 21, 2004 | 07:13 AM
94geeser's Avatar
The two fronts are not that bad to do. The rear mount is a bitch. Trust me, I just did all mine a month ago. Also, if you are going to this you need to put all three mounts in. If you don't you will get a little more vibration than you would wothout the rear mount and if your rear mount is not totally gone it will be with just the two front ones in. Another suggetion is to go buy small bolts washers and nuts instead of the zip ties. Zip ties eventually break and the inserts start squishing out. The vibration at idle is bearable but the feel of the car is great!!!!!
Old Jan 21, 2004 | 06:59 PM
inzaneN1's Avatar
Well see the problem that im having is that like around 60, 70 ,or 80 my car starts shaking uncontrollably. My rear mount has been going bad so i figured thats the problem and was told that the inserts would solve the problem. Is this happening to anyone or has happened to anyone ?
Old Jan 21, 2004 | 08:53 PM
inzaneN1's Avatar
Old Jan 21, 2004 | 08:57 PM
94geeser's Avatar
That sounds more like a suspension problem
Old Jan 21, 2004 | 09:06 PM
trustbuddy's Avatar
i feel you...
Old Jan 21, 2004 | 09:52 PM
Ls-Rturbo's Avatar
Default Re: motor mount inserts? (trustbuddy)
all the inserts are pritty easy except for the liquid fill mount by the timing belt. I had to take it to a shop to have them press out the metal sleave and it took them almost an hour
Old Jan 22, 2004 | 12:23 AM
sumyungguy's Avatar
Default Re: motor mount inserts? (bl18t)
have you had new tires installed lately? maybe they arent balenced corectly
Old Jan 22, 2004 | 10:35 PM
inzaneN1's Avatar
thing is from time to time i can go 60 - 80 without it vibrating . but eventually it will do it again. my tires are balanced had them for a year now
Old Jan 23, 2004 | 05:54 PM
inzaneN1's Avatar
bump
Old Jan 23, 2004 | 07:36 PM
SloGizzer's Avatar
i got the energy suspension ones, and the lower 2 tq mounts were not too bad to install, but the rear one was a pain in the ***, not to mention that my whole dash vibrates at idle. I think its worth it though since u can launch without having to think about ripping a mount.
Old Jan 23, 2004 | 09:04 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (SloGizzer)
for me cuz i installed the motor mount inserts while the motor was out of the car.
Old Jan 25, 2004 | 11:24 PM
inzaneN1's Avatar
im pretty much just gonna end up replacing mounts can anyone give me a price on good motor mounts something alittle better than stock but not so expensive as to how much hasport ones cost
Old Jan 25, 2004 | 11:38 PM
MR5sARECOOL's Avatar
i have them and love them
Old Jan 25, 2004 | 11:48 PM
aznsmtboy's Avatar
Default Re: motor mount inserts? (MR5sARECOOL)
I'm thinking of picking up the complete motor mounts from Jimfab.com he says that the three motor mounts that he offer now are more then enough to keep the motor still. I've heard good things from a couple of people about his mounts.
Old Jan 27, 2004 | 08:36 PM
inzaneN1's Avatar
thx
Old Jan 27, 2004 | 09:23 PM
94teggy's Avatar
I have them in mine. I loved em when i first got them because my car started to have the same feel as a "race" car. Now its a little anoying but still great when accelerating hard. Plus my car feels really responsive.
Old Jan 28, 2004 | 01:36 PM
allmotorb17a's Avatar
Default Re: (inzane)
i had the same problem, my car felt like it the engine was going to fall out every time i got around 4 to 6 grand, i found out all 4 motor mounts broke so i replaced the front and rear and threw in the inserts in the rear and sides now i feal the vibe of the monster through my whole car.
" IF ITS NOT VTEC ITS CRRRAP!"
Old Feb 26, 2004 | 12:23 AM
CRX Hybrid's Avatar
Dude do yourself a favor and get the HA sport mounts. I have a crx b16a hybrid and I wanted the same thing... mounts cheaper than hasport mounts... and about 3 months after the swap my rear motor mount got completely screwed just from a hard shift into second. Now I have to pull my motor next week and replace my crappy mounts with the hasport ones. Believe me on this one... this is one thing in your motor you can't go cheap on. You should get the HASport ones.
TypeRod
Dec 7, 2011 02:45 PM
AlienKrOZ
Jun 29, 2006 01:48 PM
94gsrhatch
Nov 20, 2004 05:35 PM
SOHC_Brian
Aug 11, 2004 11:30 AM
