Piston sizing
Old Jan 20, 2004 | 09:43 PM
theBird's Avatar
Default Piston sizing
I plan on rebuilding my b18b for turbo and I want to keep the stock 81mm bore, no sleeves. My car has 144,xxx miles on it and over time do cylinders wear and get slightly larger bores so that 81mm wont have a perfect fit? If so, would I be better off with an 81.5mm piston?
Modified by theBird at 5:26 PM 1/21/2004
Old Jan 21, 2004 | 01:27 PM
theBird's Avatar
Default Re: Piston sizing (theBird)
bump
Edit - I am planning on using aftermarket pistons, just don't know which brand. Arias, cp, wiseco are quality aftermarket pistons, what else should I look for? Thanks for the response.
Modified by theBird at 9:28 PM 1/21/2004
Old Jan 21, 2004 | 01:35 PM
mr.beeks's Avatar
are you buying aftermarket pistons?
go with the 82mm bore.
but honda does understand the size change thats why they sell
a .5 oversize...
Old Jan 21, 2004 | 05:30 PM
theBird's Avatar
What is the max size bore I would want to go with stock sleeves? 82mm sounds good to me.
raverx3m
May 20, 2014 05:32 AM
EARLdaSQUIRREL
Apr 5, 2005 07:22 PM
turbo89civicb18hatch
Nov 8, 2004 04:42 PM
swlabhot
May 20, 2004 01:44 PM
Fatty_1775
Mar 3, 2003 08:55 AM
