driver side AXLE
Old Jan 19, 2004 | 09:46 PM
EGPrelude's Avatar
Default driver side AXLE
hey,
anyone ever experience a problem of taking out the driver's side driveaxle, specifically for a 90-93 integ? i was helping a friend trying to swap trannies but we couldnt get the axle out
we got a book that says to just pop it out of the intermediate shaft but it just would budge. we kept prying and prying but it didnt come out?
any thoughts on this? help would be greatly appreciated
Old Jan 19, 2004 | 11:14 PM
JojoBananas's Avatar
Default Re: driver side AXLE (EGPrelude)
my thought is its stuck. good luck getting it off.
Old Jan 19, 2004 | 11:35 PM
wodstlk's Avatar
you need to pry both sides at the same time. i had the same problem, it took about 10 hours to get that ****** out.
Old Jan 19, 2004 | 11:54 PM
IN VTEC's Avatar
Remove the int. shaft along with the driver-side axle.
Or, just smack the inboard joint on the axle with a sledgehammer. It'll pop out. Prying won't even budge it enough to get the retainer clip to pop out of hte groove.
Old Jan 20, 2004 | 04:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
yeah I usually just remove the axle and halfshaft at the same time as one piece.
Old Jan 20, 2004 | 06:10 AM
Toda Built's Avatar
there should be three bolts from the intermediate shaft and the block. take out those three bolts and it will slide right out.
<----same thing happened to me
thats if its set up like the 94-01 integras
Old Jan 20, 2004 | 08:58 PM
EGPrelude's Avatar
thanks for the advice guys
Old Jun 16, 2008 | 08:12 AM
hondapwr's Avatar
Default Re: driver side AXLE (wodstlk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wodstlk &raquo;</TD></TR><TR><TD CLASS="quote">you need to pry both sides at the same time. i had the same problem, it took about 10 hours to get that [freak]er out. </TD></TR></TABLE>
Is there a way to get the intermediate shaft separated from the driver's side driveaxle without removing it all, or do you have to remove the driveaxle and intermediate shaft and try to separate them on the ground?
Old Jun 16, 2008 | 11:57 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: driver side AXLE (hondapwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr &raquo;</TD></TR><TR><TD CLASS="quote">
Is there a way to get the intermediate shaft separated from the driver's side driveaxle without removing it all, or do you have to remove the driveaxle and intermediate shaft and try to separate them on the ground?</TD></TR></TABLE>
Hit it with a large hammer, it's not all that tough.
btw, notice the thread date?
Old Jun 17, 2008 | 07:46 AM
lmike6453's Avatar
lol if it still helps then use a rubber mallet hitting it outward from block outward
Tommy_Gunns
Apr 13, 2009 09:39 PM
B18CYAAA
Aug 11, 2007 04:38 PM
Hoppa
Dec 5, 2006 08:51 AM
huepowered
Mar 27, 2006 12:33 PM
tominos
Jun 15, 2003 05:56 AM
