COLD AIR INTAKE??????
Old Feb 26, 2004 | 10:47 AM
bee18's Avatar
Default jacobs ignition
just kidding, seriously though i done research on MSD ignition, and compered to a Jacobs, it seems that jacobs is better for sport compact applications, i decided on going with Jacobs myself, they are a lil more expensive but it has better spark than msd, the voltage stays on a constant level of voltage through out the rpm range. my thing is has anyone ever used Jacobs ignition on a honda/acura?? and if so what are your thoughts.. oh and to be alil more informative i am going with the pro 10 ignition system. thanks
Old Feb 26, 2004 | 10:50 AM
Creep's Avatar
Default Re: COLD AIR INTAKE?????? (bee18)
you should see gains of 30+ HP with COLD AIR INTAKE!!!!
j/k
p.s bad title
SuzukaBlueAP2's Avatar
First off, why don't you be a little more serious and title a thread about exactly what you want.
2nd, MSD igntions actually produce the amount of voltage they are rated at. Most other's do not.
Not saying that one is better than the other, i've not personally compared those 2. Both are good. What are you going to be doing to your car that you need an ignition upgrade ?
Old Feb 26, 2004 | 10:54 AM
bee18's Avatar
Default Re: COLD AIR INTAKE?????? (ScreaminTeg)
going turbo, with built ls. 9.0-1 comp arias forged pistons, eagle rods, big16g turbo, and to reply i never dealt with ignition systems before i just did alot of research and asking around.
Old Feb 26, 2004 | 10:59 AM
If you're going turbo....MDS-6BTM is your friend. complete ignition with the adj. boost timing master. so you can retard your ignition timing per pound of boost you're running. Good stuff.
:edit: check out http://www.summitracing.com for that msd ignition.
T3mp3sT's Avatar
i think the title was to get us in here. u suck dude haha jk
Old Feb 26, 2004 | 11:49 AM
B2FiNiTY's Avatar
Default Re: jacobs ignition (bee18)
retarded title
JDM_COUPE94
15
May 3, 2007 03:05 PM
93civichatchinky
Aug 9, 2006 11:36 AM
MyKey
Jun 7, 2004 07:48 PM
Sleek98
Mar 31, 2003 08:25 AM
