LSVTEC Question's
Old Feb 29, 2004 | 01:03 PM
vtfrankenstein's Avatar
Default LSVTEC Question's
I got an LSVTEC and just it out for the summer here in Albany New York. I want to change the thermostat in it it has a old B16 head what should I buy for the thermostat. I also heed a timing belt what should I ask for at the honda or Acura dealership.
Advanced Thanks
Chad Denton
Old Mar 2, 2004 | 04:09 AM
99lsvtecauto's Avatar
Default Re: LSVTEC Question's (vtfrankenstein)
if u have a stock lsvtec and u want to change tbelt ask for an ls pepboys sell the tbelt for 30 new
Old Mar 2, 2004 | 08:00 AM
Rod.'s Avatar
Default Re: LSVTEC Question's (99lsvtecauto)
whatever water pump your using you buy that timing belt
Old Mar 2, 2004 | 07:39 PM
swaytec360's Avatar
Default Re: LSVTEC Question's (redturbocivic)
if ur changing the timing belt u might as well change the water pump oem is the way to go unless u wanna do greddy blue timing belt stronger gsr is the way to go more flow in the water pump need to match pump with belt or havoc matcing teeth and belt vtec would be the way to go thermostat gsr thermo getta 160 or 170 so it will run ur **** cooler since winter is over
Ennis555
Apr 11, 2017 09:21 PM
rick_rabies
Apr 1, 2009 12:59 PM
globy123
Aug 8, 2008 08:38 AM
Miz101
Feb 15, 2004 07:07 PM
1998hondaaccord
Sep 18, 2003 07:25 AM
