Idle problem!!
Old Feb 27, 2004 | 07:15 PM
Bictorious's Avatar
Default Idle problem!!
Alright.. i know theres alot of threads like this but i dont see very much with my kinda problem so i want you ask you guys. I have an LS in my EJ and ever since I used an intake cleaner to clean the manifold its been idling like crazy, bouncing rpms. revs high then llow then high, etc. This only happens when im in neutral or when i stop. what could be the problem
Old Feb 27, 2004 | 07:47 PM
shinredsun's Avatar
Default Re: Idle problem!! (Bictorious)
there is bolt that you could play with your intake manifold. try to close little bit. it might help. my old eg had a problem like that and it really help me. it wasn't perfect but it was good enough. however, you might lose top end little.
Old Feb 27, 2004 | 09:45 PM
G1 TEGGY's Avatar
Default Re: Idle problem!! (shinredsun)
just got done with my rebuild and had the same problem, don't touch the idle screw in the IM, it's vacuum, even the very slightest hole in your vacuum lines can cause this, you can just tape it with electrical tape to fix it though.. either a hole or you knocked a line loose when you were cleaning the IM.. check all the vacuum lines.
EDIT: vacuum is the number one cause, next to that it's EGR, bad fuel injection, and busted pulleys/belts
Modified by G1_TEGGY at 10:18 AM 2/29/2004
PROJECT 91
Sep 25, 2009 11:18 AM
julianbc2
May 12, 2009 01:33 PM
longshot
Nov 30, 2008 10:44 AM
rice a roni
12
May 24, 2005 12:31 PM
galioth
Oct 28, 2004 03:47 PM
