need help!?
Old Feb 28, 2004 | 07:52 PM
hollaback6's Avatar
Default need help!?
ok well i am prett sure i need a new clutch but let me tell you the symptoms. clutch is really soft and doesn't stiffen till it's almost on the floor. The clutch won't pop back out unless being drive(warmed up). Car is hard to get in gear. The shifter moves freely but when the car is cold i have to force it into gear. I had this stock clutch since i bought the car a year and half ago. It has been used with boost for about 10 months. setup consists of a 14b at 10 psi. Do i just need a new clutch? Could it be the master cylinder? any other ideas. Thanks.
Brian
Old Feb 28, 2004 | 08:25 PM
xSCTYGx's Avatar
Default Re: need help!? (hollaback6)
what kind of car do u have now?
Old Feb 28, 2004 | 08:57 PM
ImporttRacerr555's Avatar
Default Re: need help!? (2Gen91Teg)
It sounds to me like your burned up your clutch, but i would check the clutch lines cause it sounds like its not wanting to keep pressure so you could have a leak, so check your clutch fluid to see if its low, But having to force into gears could mess up the bearings on the tranny so be careful with that and i would also check check your tranny fluid cause if its to old that could make it a little rougher to shift into gears, so that would be a good thing to change.
Old Feb 28, 2004 | 10:12 PM
hollaback6's Avatar
Default Re: need help!? (ImporttRacerr555)
i have a integra. Yeah i figured i my clutch is done. The car is not being driven now so i won't be having to force it into gear. I am getting another clutch and will change my tranny fluid also. thanks for the help.
Slow Egg
11
Jun 26, 2017 11:25 PM
andlude
Apr 5, 2012 07:45 PM
vortexx
Aug 24, 2006 12:13 PM
pompom
Feb 7, 2006 05:12 AM
OSG 97 ITR
Apr 17, 2004 10:11 AM
