compression for LS short block
Old Feb 26, 2004 | 12:49 PM
projectEK9's Avatar
Default compression for LS short block
This is my first time posting in the Integra forum and I have a quick question for you guys and gals. Im buying a LS short block off a guy and the only thing he could tell me "The only information I can really give you is the compression test 75/160 on all cylinders and under 10% on the leakage test." How is that for a motor from 95 with 75K miles?
Old Feb 26, 2004 | 02:12 PM
SuzukaBlueAP2's Avatar
Default Re: compression for LS short block (projectEK9)
I've seen good numbers off of B18C's that are in the 180 range.
75 seems a bit low for that motor.
Old Feb 26, 2004 | 02:14 PM
95integraLS's Avatar
i dont get it...what were the numbers on each cylinder of the compression test? i dont know what 75/160 means.
Old Feb 26, 2004 | 02:17 PM
Default Re: (95integraLS)
When you do a compression check on an engine, those numbers represent how many pounds per square inch each cylinder is holding.
If the numbers are low, there is a leak somewhere. Could be the piston rings, or it could lie in the head. Warped deck, a problem with the valves. There are various way to detect where the leak is coming from as well.
Old Feb 26, 2004 | 02:21 PM
Default Re: (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">When you do a compression check on an engine, those numbers represent how many pounds per square inch each cylinder is holding.</TD></TR></TABLE>
if that was towards me, i know what a compression test is...i dont know why his test results are 75/160 instead of giving a reading for each cylinder(ie. 180 175 180 185)...thats what i was trying to say.
Old Feb 26, 2004 | 02:22 PM
my bad 95integrals....it sounded like you didn't know what one was. lol sorry...
Old Feb 26, 2004 | 02:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">my bad 95integrals....it sounded like you didn't know what one was. lol sorry...</TD></TR></TABLE>
its cool...i know post count means EVERYTHING when it comes to forums.
Old Feb 26, 2004 | 03:44 PM
projectEK9's Avatar
hmmm thanks alot guys...i do plan on gettin the pistons replaced IF i get the block...hopefully thats the problem... thanks again
Old Feb 27, 2004 | 03:56 AM
JimBlake's Avatar
Default Re: (projectEK9)
What do compression numbers mean on a SHORTblock anyway?? If 1 or 2 cylinders are low, it might be the headgasket or the valves. NETHER of which are part of the shortblock...
FinedTuned
Jun 13, 2009 05:09 PM
-Darren-
May 23, 2006 02:29 PM
sdinteg
Feb 1, 2005 07:52 PM
Phat Corolla
Aug 13, 2002 03:50 PM
Jamison
Feb 11, 2002 08:51 PM
