Vtec System Malfunction
Old Feb 28, 2004 | 05:59 PM
Warhead's Avatar
Default Vtec System Malfunction
My friends Teg is throwing code P1259, Vtec System Malfunction. And the Vtec doesnt kick in until 500rpms before the rev limiter. Can anyone tell me what could be causing this, and how to fix it?
Thanks
Old Feb 28, 2004 | 06:16 PM
vain's Avatar
Default Re: Vtec System Malfunction (Warhead)
check the oil levels?
Old Feb 28, 2004 | 06:39 PM
Warhead's Avatar
Default Re: Vtec System Malfunction (vain)
Plenty of oil, the light has been on for a while, we just now got it checked.
Old Feb 28, 2004 | 07:25 PM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warhead &raquo;</TD></TR><TR><TD CLASS="quote">And the Vtec doesnt kick in until 500rpms before the rev limiter. </TD></TR></TABLE>
how do you know this?
Old Feb 28, 2004 | 07:29 PM
Ti3d in's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warhead &raquo;</TD></TR><TR><TD CLASS="quote">My friends Teg is throwing code P1259, Vtec System Malfunction. And the Vtec doesnt kick in until 500rpms before the rev limiter. Can anyone tell me what could be causing this, and how to fix it?
Thanks</TD></TR></TABLE>
Check the VTEC solenoid.
Old Feb 28, 2004 | 08:17 PM
white ex's Avatar
if the code says its a vtec system malfunction then i dont think vtec would be engaging, and also wouldn't that cause the ecu to go into limp mode ? if so your probably hearing the secondaries open not vtec.
Old Feb 29, 2004 | 09:50 AM
Warhead's Avatar
Default Re: Vtec System Malfunction (Ti3d in)
Well it could be the secondarys that we're hearing. I just know it gets really loud ~500rpms before redline. How do I check the Vtec solinoid.
Old Feb 29, 2004 | 10:17 AM
math labs's Avatar
I dont event hink you should be going into vtec range if its throwing a vtec code. You can check if the solenoid is plugged in, which it usually is, it takes finger effort to take it off.. But its to the left of the head when looking down at it, it has a green plug going into it usually.
and yea, it should be in limp mode
slowr6
Mar 27, 2007 04:51 PM
poppypizza
Sep 2, 2006 03:41 PM
Down Shift Motoring
Apr 10, 2006 07:06 AM
JunY
Honda S2000
18
May 17, 2005 09:37 AM
endlesswinterco
Jan 3, 2004 10:34 AM
