new here! help!!!
Old Mar 4, 2004 | 06:41 PM
ehhhdc2's Avatar
* B A N N E D *
Default new here! help!!!
hi im noob here, i have a 97 gsr. um i have some problems hopefully u guys will help me out? first of all, the signal light on the left doesn't seem to work. whenever i turn on my headlights i see the turn signal's arrow on the cluster. it doesn't blink but it stays on. . The right turn signal seems to work ok. any suggestion?
Old Mar 4, 2004 | 06:48 PM
LSTEG96's Avatar
Default Re: new here! help!!! (97gs-r)
search, and look at the wiring?
Old Mar 5, 2004 | 07:08 AM
JimBlake's Avatar
You're gonna want to get comfortable with using a circuit drawing & a DMM. There's lots of places for wires to get pinched, loose, or corroded. Chances are yours won't be screwed up in the same place as anyone elses.
Bulbs OK? The dual-filament bulb on the left might be stuck backwards into the socket? Open ground somewhere around the corner light??
Old Mar 5, 2004 | 09:53 AM
mrwink's Avatar
Default Re: new here! help!!! (JimBlake)
does your corner light stay on instead of alternating? if so, like someone said, the bulbs are "double contact" which means that there are two metal ***** on the bottom of them. if one goes out, it wont blink any more. you probably just need to replace the bulb. just make sure you replace it with the correct size and that it is a double contact bulb.
Old Mar 5, 2004 | 09:55 AM
IntEGNYC's Avatar
Default Re: new here! help!!! (mrwink)
check the bulb to see if its burnt out.
Mister_1
Honda Civic (2006 - 2015)
Jun 5, 2018 05:36 PM
lilboxx
Apr 11, 2012 08:18 AM
Colby71
13
Dec 31, 2006 03:40 PM
niteboyzzz
Oct 4, 2002 11:24 PM
