CEL is on solid
Old Mar 7, 2004 | 01:45 AM
95LSS's Avatar
Default CEL is on solid
I tried to pulled the codes from my computer(1995 Integra LS) and the cel light is on solid. My service manual is vague on what that means and I couldn't find a list here of the codes. Anybody know what that means?
Thanks,
Old Mar 7, 2004 | 01:54 AM
tegmech's Avatar
check engine light. Something is wrong. http://www.c-speedracing.com/faq.php ...how to on checking and reading ecu codes.
Old Mar 7, 2004 | 03:52 AM
95LSS's Avatar
Default Re: (tegmech)
That's the same procedure I followed but there doesn't appear to be a defination for a solid CEL. I hope it's doesn't mean the computer is fried and it can't generate any codes.
Old Mar 7, 2004 | 06:36 AM
stasi's Avatar
Default Re: (95LSS)
From what I've been told, a solid CEL means you're due for maintenance.
Old Mar 7, 2004 | 08:54 AM
95LSS's Avatar
Default Re: (stasi)
The code I was hoping for was 15(ignition output signal). My car won't start and I've traced it down to either the ignition control module or an ecu problem.
Old Mar 7, 2004 | 09:27 AM
SecretAznMan4u's Avatar
hey, I think its on solid because there is nothing wrong with it. You stated you car won't start right? In order for a CEL to work the engine has to start.
Checked for spark?
Checked for air?
Checked for fuel?
I would say coil or ignitor.
Old Mar 7, 2004 | 09:28 AM
Default Re: (95LSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stasi &raquo;</TD></TR><TR><TD CLASS="quote">From what I've been told, a solid CEL means you're due for maintenance.</TD></TR></TABLE>
thats what the "maint" light does, not CEL
Old Mar 7, 2004 | 10:41 AM
95LSS's Avatar
Default Re: (SecretAznMan4u)
Here's what I've confirmed:
No spark: used a spark plug tester
Has air: I can hear the air moving thru the exhaust.
Has fuel: I can smell it when I pull out the spark plugs.
Electrically the coil tested fine, all of the resistances were within spec. When I went to test the ignitor, all but 1 of the wires read +12 volts. The odd-ball wire read 3 volts and according to the service manual that mean an ECU problem.
Old Mar 7, 2004 | 10:42 AM
you can take that ignitor to Autozone. they have a tester there. ECU just don't burn man, I am hoping thats not it.
Old Mar 7, 2004 | 11:00 AM
95LSS's Avatar
Thanks... I didn't know Autozone had a tester. All I'm able to test is the input voltages since it's solid state electronics.
ls19integra95
Feb 26, 2008 07:16 PM
H22AEG2
Aug 10, 2005 02:56 PM
megaman096
Oct 25, 2004 05:27 PM
beeroh
Sep 24, 2004 08:16 AM
PiYoImuT
Oct 14, 2001 08:14 AM
