Quick Koni Yellow Question
Old Mar 7, 2004 | 03:01 PM
Xsi's Avatar
Xsi
Default Quick Koni Yellow Question
Are the rear shocks supposed to have the ring that goes over the circlip like the front ones do, or are the circlips held in only by the perch?. I can see where it would sit in place on the bottom of the perch but it doesn't seem as well secured as the fronts.
Thanks in advance
Old Mar 7, 2004 | 04:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Quick Koni Yellow Question (Xsi)
I think at some point they were redesigned. My Konis which I bought for my DC2 a little over 2 years ago have the rings on all 4 shocks (circlip, then ring, then spring perch). I think you can tell but looking at the size of the groove around the inner edge of the spring perch. If it looks like the groove is bigger than the circlip, then you probably need those rings. If the groove fits just right over the circlip, then you probably don't need the rings.
Old Mar 7, 2004 | 04:54 PM
Xsi's Avatar
Xsi
OK, thanks. They are brand new so should be the new design, they have a groove that is just the right fit for the circlip but it isn't very deep, i guess with the pressure from the spring they should be ok
Old Mar 7, 2004 | 05:57 PM
Groove_D's Avatar
Default Re: (Xsi)
mine are the same.
i was wondering the same thing, but i guess that is the way it should be.
Old Mar 7, 2004 | 10:20 PM
Community Builder
Default Re: (Xsi)
Yes the spring usually holds everything in place, unless the perch is low enough that the spring might be loose (like is the case on my car). But when the assembly is on the car and the car is on the ground, the weight of the car compresses the spring/shocks assembly so it all stays in place.
Old Mar 8, 2004 | 12:51 AM
Xsi's Avatar
Xsi
Default Re: (PatrickGSR94)
Thanks, all installed now but ran over a nail so have to get my tire repaired before I can test them
The springs are captive so it should be fine, here in NZ it's illegal to have uncaptive springs anyway
hella_usdm
Suspension & Brakes
May 24, 2006 10:01 AM
Rocco.
Mar 23, 2005 08:18 PM
Neo
73
Nov 26, 2002 03:32 AM
PatrickGSR94
Feb 15, 2002 11:38 AM
