obd question
Old Apr 16, 2004 | 08:34 PM
t . b o z's Avatar
Default obd question
I have a 90 DA 'teg with a 94-97 b18b. The deal with it is that the guy before me kept all the obd0 **** on the newer motor. ECU, harness, injectors....etc. Im planning to do an ls-turbo and from what I understand, you should convert to obd1 when going with Hondata. How hard is this conversion, and what am I going to need? I assume Im going to need a obd0 to obd1 conversion harness...but I know that cant be all there is to it.
Old Apr 16, 2004 | 09:09 PM
Colin's Avatar
Default Re: obd question (TimmydaTeg)
its a pretty easy conversion
http://www.g2ic.com/forums/showthread.php?t=86612
Old Apr 16, 2004 | 11:48 PM
riceball777's Avatar
i would just get hondata for obd0 which is a stage 2 or 3
too much money and trouble and money to go to obd 1 if u ask me
you will need a new edu $200 dizzy $150-200 harness 100-1xx
Old Apr 17, 2004 | 12:07 PM
t . b o z's Avatar
bump for other opinions
Old Apr 17, 2004 | 01:26 PM
Colin's Avatar
Default Re: obd question (riceball777)
its not that expensive to go obd1, a LOT of the time the only cost is the jumper harness. Often people buy a motor that already comes w/ the correct obd1 electronics, and it would actually be more of a hassle to find the correct obd0 parts than to just buy a jumper harness and convert.
Newman is selling jumper harnesses right now for $119 shipped... damn good harness and damn good price.
A hondata stage 2 system for boost will retails for $545, a stage 3 is $725, however if you're obd1 then s100 w/ boost is $445 and the s200 w/ boost is $495 (obviously you can add more options which will raise the price). So, considering on the setup you want to run, it might not be any more expensive to run an obd1 system opposed to an obd0 system. And in general obd1 is a bit better than obd0... just newer technology.
mozzandherb
Sep 18, 2014 12:15 PM
shortshift89
Aug 30, 2007 05:05 PM
Mikey361
Apr 17, 2005 07:19 AM
euy
Aug 4, 2004 07:15 PM
