exhaust problem
Old Apr 18, 2004 | 10:27 AM
babes 99 GSR's Avatar
Default exhaust problem
Hey guys, i recently installed toda header, cat, type one b-pipe, and spoon n1. Everything was installed correctly, but the b-pipe (at the bend) hangs very low. Anyways, i autocrossed the car today...the b-pipe was actually moving up and down during the event, which caused a leak (car sounds funny). It is hanging even lower now. I haven't heard any scraping, but it's definitely a problem. I didn't finish the event, which pisses me off. I feel like something needs to hold it up more near the bend. I don't know how to weld and would need someone to take care of this problem for me. My question is...has anyone taken their car to a muffler shop, and if so, how much does it cost? Basically, i need something added to hold up the middle part of the exhaust...and also just tighten everything up again. How much would that cost, any ideas? How long does something like that take? I know this doesn't sound like a big deal...but it's bothering me now. Has anyone had similar problem with type one b-pipe? Hm...
-Staci
Old Apr 18, 2004 | 12:04 PM
Default Re: exhaust problem (99GSR1980)
Come on...does everyone on here have perfect installs? I doubt it...help a girl out...i have a few questions, which are above.
-Staci
Old Apr 18, 2004 | 12:11 PM
Smeeg Heed's Avatar
is the header a big 4-1 JDM style one (which would explain the much lower ground clearance)? seems like something wasn't secured properly if you're getting that much movement under there...
If the exhaust sounds like it's broken then possibly a flange broke off part of the piping or the cat. Still it seems very strange that you would be getting enough movement for the exhaust to actually break. You're sure you didn't smack the bottom of the header or anything on any part of the ground, right?
Old Apr 18, 2004 | 01:13 PM
Default Re: exhaust problem (NS98GSR)
No, the header is toda's 4-2-1...and it has excellent ground clearance. The header isn't really part of this problem though and is an excellent piece...it's the b-pipe that's ruining my day. Basically i'm having problems between the cat and spoon n1. The exhaust doesn't sound broken (flanges did not break), but i know there is a leak...you can see a gasket kinda sticking out. The b-pipe hangs too low and was moving a lot during today's race. I think the movement of the b-pipe caused things to loosen up...and now there's a leak. I have pretty much identified the problem, my questions are...how much do you guys think it would cost to have this taken care of at a muffler shop? Basically, i need another hanger welded on...or something needs to be done to hold the middle part up higher. Also, everything will have to be tightened again. I don't believe anything was actually damaged.
-Staci
Old Apr 19, 2004 | 10:57 AM
Not that anyone really cares, but i took the car to a muffler shop and they shortened my type one b-pipe...things are good again. Car is better than before. Yay. Anyways...
-Staci
Old Apr 25, 2004 | 05:28 PM
porschekremer's Avatar
bump, def. for your car **** was one of the nicest i've seen.. clean teg. saw you at cruisne night in bing. you came w/ mike.... def. showin that females are doin it right, zeal suspension, toda, header, spoon exhaust.. and that was just what i know about it...
Old Apr 25, 2004 | 07:00 PM
stumpyf4's Avatar
How much need to be removed?
Old Apr 25, 2004 | 07:50 PM
Default Re: exhaust problem (stumpyf4)
Um...it was shortened a bit, nothing was actually removed. They cut the pipe toward the front end, but not the flange. They then expanded the shorter part (diameter increased a little) and fit the longer part in a little...so it shortened in length...then they welded it. Not sure why it wasn't fitting...the parts weren't specifically made for my gsr, so maybe that's it...don't know. I wasn't too happy that they cut my $300+ b-pipe, but things weren't working. It's running really well now however.
And cruisner - thanks dude.
-Staci
civic1234
Dec 23, 2006 10:43 PM
dblock
Sep 18, 2006 08:15 PM
seanb18c1
Oct 20, 2003 06:32 PM
ngolimit408
Dec 18, 2002 04:28 AM
Woody_geeser
Jun 22, 2001 02:46 PM
