fishtank in the trunk!
Old Apr 16, 2004 | 05:13 PM
oMek's Avatar
Default fishtank in the trunk!
i know tegs get water in the hatch because of the sunroof tubes. ive never had a problem with it at all then about 2 weeks ago there was TONS of water back there!
today i washed my car and again it got full of water.
so i wint home and pulled the pannels off and the tubes where in there spot and dry as can be. i know its not tthem because there was a bunch dust built up and if it was leaking it woulda washed that away.
i checkd all around the tail lights and all around the hatch and i cant find the leak.
anyone got a idea?
Old Apr 16, 2004 | 05:16 PM
wanna b R's Avatar
Default Re: fishtank in the trunk! (oMekoneDC2)
wash your car again...tell some 1 to stay in the car with the panels off and look where is it leaking?
Old Apr 16, 2004 | 06:59 PM
xplanetearth420x's Avatar
Default Re: fishtank in the trunk! (wanna b R)
what oart of your car is it leaking from the front back left or right?
Old Apr 16, 2004 | 07:01 PM
Kendall's Avatar
Where exactly is the highest point that indicates the presence of water?
Old Apr 16, 2004 | 07:12 PM
GG-SquadDB's Avatar
Default Re: (Kendall)
my guess would be the trunk seal??? but i dunno u checked all the places i would have...hope u figure it out
Old Apr 16, 2004 | 07:23 PM
B18CRacer's Avatar
usually is the trunk seal or the tail light seals....best to get new seals.
Old Apr 16, 2004 | 09:55 PM
Audi A4's Avatar
Default Re: fishtank in the trunk! (B18CRacer)
have u removed the tail lights at anytime?
Old Apr 17, 2004 | 12:11 AM
oMek's Avatar
Default Re: fishtank in the trunk! (DRAG lll INTEGRA)
its not from the tail lights. i can tell it comes from the driver side of the car. im thinking maby the s2k antenna might be the cause. but ive bin getting LOTS of water that much should not be coming threw the antenna hole.
Old Apr 19, 2004 | 05:19 PM
integramic's Avatar
I have had problem with the small windows leaking twice. Also had prblems with the windshield and wheelwells.
Old Apr 19, 2004 | 05:52 PM
luvinmyGSR's Avatar
Default Re: (integramic)
had the same problem....let some 1 get in the bak and with a flashlight and get sum1 else to hose it down for a lil while and see where its comming from...i used liek black silicon i think and it fixed it rite up
Old Apr 19, 2004 | 06:09 PM
deepgreengsr's Avatar
Default Re: (luvinmyGSR)
there is a spot weleds seam above the headlights where the seam sealer cracks off. Mine has done it on both sides, and I have never been in a accadent. Im me for a pic. im fixing mine right now I can show you where to put the seam sealer. Pull off your light and look at the top of the seam you will see a crack. this is prolly the problem or its you s2k antenna. both should be easy to solve.
Old Apr 19, 2004 | 07:29 PM
Ditdogs's Avatar
Default Re: (deepgreengsr)
i wasted so much time trying to figure out where i am getting leaks from in my dc2 trunk, so i just said faq it and drilled 2 little holes in the deepest part of the trunk. it still leaks but it drains out now.
rein1116
Jun 6, 2007 07:35 PM
RedRocketDX
20
Sep 17, 2006 06:41 AM
swappedcx
Nov 9, 2005 09:14 PM
jamal-188
Apr 9, 2005 07:47 AM
crewjones
Dec 22, 2002 02:35 PM
