Piston question. searched
Old Apr 14, 2004 | 06:32 PM
J-g-D-s-M-r's Avatar
Default Piston question. searched
i plan to rebuild my motor since im burning oil. burning oil so i need new piston rings. since im getting those i plan to get new pistons as well. here's my question. when i plan to get new pistons and rings. do i need to get anything else?? rods?.... it's like getting new cams where i need to bump my valve train. so if i get new pistons what else do i need to get to make my car running fine?? ran a search but couldn't find anything. and any suggestions on best daily pistons? if there is such a thing. im kinda new to the internal motor stuff.
TIA
Old Apr 14, 2004 | 06:48 PM
Default Re: Piston question. searched (J-g-D-s-M-r)
bump
Old Apr 14, 2004 | 06:51 PM
Kendall's Avatar
You will need new rod bearings and a new headgasket. I would also get new wrist pins. What engine do you have, and does it currently have stock pistons?
Old Apr 14, 2004 | 07:06 PM
Default Re: (Kendall)
stock gsr. i want something like jdm itr pistons or jdm ctr pistons. or is there something better?? ive heard good things about ctrs.
Old Apr 14, 2004 | 08:19 PM
Default Re: (J-g-D-s-M-r)
up
Old Apr 14, 2004 | 08:21 PM
Kendall's Avatar
JDM ITR pistons will put you to approximately 11.3:1 compression. JDM CTR's will put you much higher than that. I wouldn't recommend going with the CTR's unless you plan on bigger cams and appropriate valvetrain mods.
Old Apr 14, 2004 | 08:33 PM
cool thanks. very helpful
egkingfl
Aug 31, 2009 09:36 PM
b18ek670
May 2, 2006 04:54 PM
lilredhatch
Apr 12, 2004 11:56 AM
wm5holla
26
Jul 26, 2003 12:50 PM
