O2 sensor on cat
Old Jul 31, 2004 | 12:03 PM
95BlkGSR's Avatar
Default O2 sensor on cat
when i bought my car the Check engine light was on, but the guy i bought it off of said the O2 sensor needed plugged in, so today i looked at my friends integra and i put mine in the same way, but the check engine light is still on.............will it go away after the computer cycles? or do i have a bigger problem
Old Jul 31, 2004 | 12:33 PM
aznballer's Avatar
does ur friend have a good o2 if he does thenthats not ur prob
Old Jul 31, 2004 | 01:15 PM
TrueUntilDeath.com's Avatar
Default Re: (aznballer)
check the ecu code to make sure its that sensor.
Old Jul 31, 2004 | 01:50 PM
dc2drifterx's Avatar
Find out what code you are throwing so we can get you a better answer. And you said the guy you got it from said it was unplugged. Was it? Did you try resetting your ecu?
Old Jul 31, 2004 | 10:26 PM
95BlkGSR's Avatar
Default Re: (dc2drifterx)
it was unplugged and i match it up and plugged it in, im thinking ima have to get the computer tested, what u guys think?
Old Jul 31, 2004 | 10:29 PM
RidinStock's Avatar
Default Re: (95BlkGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BlkGSR &raquo;</TD></TR><TR><TD CLASS="quote">it was unplugged and i match it up and plugged it in, im thinking ima have to get the computer tested, what u guys think?</TD></TR></TABLE>
At least check what code it's throwing. No point in wasting $$$ if it's something simple.
Old Aug 4, 2004 | 01:08 PM
95BlkGSR's Avatar
Default Re: (RidinStock)
How do i check the code?
Old Aug 4, 2004 | 02:33 PM
IVI's Avatar
IVI
https://honda-tech.com/zerothread?id=682412<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BlkGSR &raquo;</TD></TR><TR><TD CLASS="quote">How do i check the code?
Old Aug 4, 2004 | 02:34 PM
IVI's Avatar
IVI
Default Re: (IVI)
also how did you plug it in? was the wires pulledo ut of the harness?
is it a 4 wire?
2 blacks can not be interchanged, they have specific spots.
Old Aug 8, 2004 | 12:23 PM
95BlkGSR's Avatar
Default Re: (IVI)
i tried both black wires in both if the black slots
Old Aug 8, 2004 | 12:25 PM
blacknbean's Avatar
ya u should reset the ecu after you plugged in the o2 sensor. either disconnect the battery or pull the back-up fuse i think.
Old Aug 8, 2004 | 05:11 PM
IVI's Avatar
IVI
Default Re: (blacknbean)
yah you should reset the ecu.
when i reconnected my oxygen sensor i had to reset it for it to go out.
Old Aug 8, 2004 | 05:13 PM
gsrboi80's Avatar
Default Re: (IVI)
reset ecu
the_0ne
Jul 16, 2006 08:01 PM
hndacord02
Jan 18, 2006 12:02 PM
Koyoloeor
Oct 13, 2005 04:57 PM
krmdds08
Apr 26, 2005 07:26 AM
Ishouldbebanned
Apr 1, 2005 09:03 AM
