Missing or skipping at 1400rpm
At cold start my car spikes to 1400rpm where i have noticed a hesitation almost like it were using a high profile cam but only does it till 1500rpm once the car gets warm obviously it lowers idle and idles fine (slightly low-but thats a diff problem). However if i slowly increase gas through the rpm range it will almost stick at 1400 and stumble until i give it a little more gas and then proceeds through the power band. You cant really feel it while driving or under load but its annoying and i need to fix it. someone tell me if they have had the problem before. Im gonna change the plug wires and the dis cap and see if that helps any other ideas?
Tony
Tony
