header questions
start in the middle, work your way out. dont go all the way out to one side, then all the way out to the other, work your way out to both sides evenly. torque spec is 23lb/ft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 »</TD></TR><TR><TD CLASS="quote">start in the middle, work your way out. dont go all the way out to one side, then all the way out to the other, work your way out to both sides evenly. torque spec is 23lb/ft.</TD></TR></TABLE>
I'm looking at the Helms right now. It doesn't list it for the center bolts, but the outer two nuts are supposed to be torqued to 23ft-lbs as 3.504 said.
I'd just do as he said and tighten them in a sequence from the middle outward at 23ft-lbs as well.
Atomic1
May 18, 2013 07:54 PM
Dangger
Sep 22, 2006 05:41 PM
