header and cat Gaskets
Old Aug 5, 2004 | 09:03 PM
94gsr_vtc's Avatar
Default header and cat Gaskets
hey guys i just got my comptech 4-2-1 header and 2.25" carsound cat to match up with my evo exhaust(60mm). it didnt come with any gaskets or anything so i need to know what i have to get before the install. i hear i can reuse the gasket between the header and block cause its metal but what about for the cat. any input would be appreciated thanks
Old Aug 6, 2004 | 06:03 AM
94gsr_vtc's Avatar
Default Re: header and cat Gaskets (94gsr_vtc)
ttt
Old Aug 6, 2004 | 06:09 AM
3.504's Avatar
you need to get the honda "donut gasket" that goes in between the header and cat if you did not get one with the stuff. the gasket that goes between header and head is re-usable. If the header is 2 piece, you need the o-ring crush gaskets that go between upper manifold and down pipe. that's all you'd need.
Old Aug 6, 2004 | 07:32 AM
starbrite's Avatar
We just did the same thing to my boyfriend's GSR, and we reused the header gasket (it was fine).
I don't remember what we used for the cat/header...I will have to ask him.
Old Aug 6, 2004 | 10:11 PM
94gsr_vtc's Avatar
Default Re: header and cat Gaskets (starbrite)
thanks peoples. i bolted the header up today(ILOVECOMPTECH) and tried to do the cat but ran out of time when we realized the cat bolts were too short. o well.
Old Aug 6, 2004 | 10:12 PM
94gsr_vtc's Avatar
-does it matter the the cat has two holes for the O2 sensor. im only using one and the other is plugged up. my car is obd1 94 gsr if that matters. i bought it off someone with a 97 gsr tho. will it work fine? thanks
Old Aug 7, 2004 | 12:36 AM
aeon's Avatar
i think it would be fine as long as you plug up the one that isn't being used. also, doesn't the obd1 integras have the plug hole on the header?? i have an ls and my cat doesn't have a plug for the sensor on it, only the header does.. might be different between the gsr and ls though.
Old Aug 7, 2004 | 08:19 AM
94gsr_vtc's Avatar
Default Re: (aeon)
thanks man, well the header doesnt have an o2 hole but the cat has 2
redDAinteg
Jun 29, 2005 02:42 PM
98vsmferio
13
Dec 29, 2004 03:09 PM
Yesman
23
Jul 25, 2002 04:59 PM
citanest
Jul 19, 2001 12:41 PM
