ls/vtec
Old Aug 6, 2004 | 05:51 AM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default ls/vtec
hey i really need help with this every where i looked i could not find the answer to this question...if i do the lsvtec ....does the head need to be the same obd of my car? see i have and obdII and im trying to keep it and i need to know if i need an obdII head or if it doesnt matter what obd the head is?please help
Old Aug 6, 2004 | 06:02 AM
3.504's Avatar
Default Re: ls/vtec (TeGmAn18)
nope, doesn't matter. i'd really recommend obd1 jumper harness though. you'll have alot less trouble using an obd1 system and you can use a chipped p28 (pretty cheap).
the heads are all the same cast, sometimes a bit different on sensor location. the main difference will be the sensor harness plugs themselves, and the most difference you'll see is injector pig tails and distributor plugs.
4door93civic
Apr 11, 2007 04:05 PM
puertoroc7976
Oct 10, 2006 05:19 PM
andysrex
Feb 26, 2006 06:44 PM
cr9m5
Oct 19, 2005 09:41 PM
Dennis93ac
Oct 30, 2003 03:51 AM
