problem with using claybar
Old Aug 8, 2004 | 04:30 PM
shyboy817's Avatar
Default problem with using claybar
well i just washed my car with meguiars goold class shampoo , and then i used the quick detail that came with the clay bar lil kit, it says spray and then use the claybar, and then i wiped it off iwth terry clothe...well after doing my hood only i've noticed some smears or something that i cannot get rid of? really bugging me and it's quite alot of spots on my hood..=\ i did it on my rear bumper but nothings wrong with it.. i was going to wax with zymol wax but i couldnt really get the spots off?
Old Aug 8, 2004 | 04:33 PM
Gerbilo's Avatar
Default Re: problem with using claybar (shyboy817)
it will smear a lil if it doesn't have enough lubricant. you should just be able to rub those marks out though.
Old Aug 8, 2004 | 04:34 PM
shyboy817's Avatar
i have tried to use water on terry clothe towel to rub it off, then dried it, but i still see it, really bugging me , i tried to wipe the whole hood and i still see it also is the claybar suppose to turn to a different color? ...thought it'd clean my car even more but it even made it worst
Old Aug 8, 2004 | 05:16 PM
IVI's Avatar
IVI
Default Re: (shyboy817)
after you do the claybar with the quickspray, your supposed to immediatly wax that area with the little bottle of wax that they supplied you with.
your supposed to work a body panel at a time.
spray throughly
use claybar until you feel no more rough spots and clay glides smooth
wipe off excess spray with a terry cloth
apply wax until dry to a haze
wipe off wax with another clean terry cloth.
Old Aug 8, 2004 | 05:45 PM
Vi3tboy's Avatar
after you clay your sposed to wipe off right away then after doing your car in sections and finishing your whole car you go and rinse your car again. then apply sealent and/or wax and watever else you chose to do
Old Aug 8, 2004 | 08:20 PM
dFreezy's Avatar
Default Re: (Vi3tboy)
wax over it, it should pull it off...i couldnt buff out some cheap wax one time on my finish so i used some nufinish 2000 on top of it and it pulled right off
Old Aug 8, 2004 | 09:20 PM
Gsr94black's Avatar
Default Re: (bl@sterVT)
I work at a detail shop and we never do a panel at a time...you can do the whole car and then go back and wipe it off without anything bad happening. The chemical that is sprayed on there is basically a deluted show shine (windex for your paint). If there are streaks then you can simply spray it and rub the clay bar back over it. the clay bar is going to get dirty even after you washed your car b/c if the car has any oxidation it doesn't just wash off. Waxing it afterward is an option but it will make the car look even better.
Old Aug 8, 2004 | 09:22 PM
gser67's Avatar
yeah when it changes the clay bar a different color thats when you know its working...thats all the contaminats coming off your paint...just follow the directions very carefully and like everyone said just do 1 body panel at a time so the lube doesnt have time to dry at all before you wipe it off.............then wax it
Old Aug 8, 2004 | 09:42 PM
shyboy817's Avatar
ok, i'll do it again tomorrow...do i have to re-clean the car to claybar it? i really dont want to do it over .. so i should spray the quick detail, clay bar, wipe, on each spot , then rinse the wohle car just with water? or what? then i should wax? i bought zymol wax..and some little circle hand buffering thing, i'm not sure how to wax either i've never done neither of this , also have a pack of terry clothes
also if anyone has aim, aim me at quakerroatmeal please thanks
supracrx
Paint and Body
Dec 28, 2008 11:26 PM
nukem2k5
Mar 23, 2005 11:05 AM
OG SHG_EM1
Nov 3, 2004 06:29 AM
LsNrG
Aug 22, 2003 05:31 PM
enthusiast128
Jan 27, 2002 08:47 AM
