pirching shocks
Old Aug 7, 2004 | 09:31 PM
gsr_to_the_MAX's Avatar
Default pirching shocks
how do you pirch shocks, i heard about doing them, but i dont have any idea on how to. can you pirch the adjustable tokicos?
Old Aug 7, 2004 | 09:51 PM
3.504's Avatar
Default Re: pirching shocks (gsr_to_the_MAX)
pirch is the area the spring rides on. so by pirching i'm guessing you mean alter the struts by moving the pirch up or down for ride height. the pirch is welded in place, the only way to move it would be cut and re-weld. some struts come with adjustable pirches (coil-overs) and then you can buy coil-over conversions that come w/ a threaded sleeve and pirce system that can be adjusted up and down. on some aftermarket struts, you can repirch into keyed points, but you have to remove the strut and go from there.
just so we get this strait:
strut = part of suspension that is neccessary, i.e. you remove it and the car will be on the ground
shock = part of suspension that you could remove and still drive w/o. trucks have shocks (along with plenty of other cars, usually on a solid axle setup) if you took the shocks off a truck, it would be bouncy, but the truck would still be able to drive just fine.
Modified by 3.504 at 7:07 AM 8/8/2004
Old Aug 7, 2004 | 11:21 PM
IVI's Avatar
IVI
Default Re: pirching shocks (3.504)
just because a shock is adjustable doesnt mean it has an adjustable perch.
the only shock i know that the perch adjusts is the koni yellow.
all other 'adjustable' shocks mean that you can adjust the softness or stiffness of the dampening.
kirkland08
Suspension & Brakes
11
Feb 28, 2011 05:51 AM
96WhiteOnBlack
Mar 19, 2007 09:09 PM
dubxl152
15
Jan 6, 2003 11:59 AM
HapiHonda
Nov 16, 2002 07:48 AM
Jordan_4WS
Oct 8, 2001 02:25 PM
