odd gearbox issue
Old Aug 7, 2004 | 06:26 PM
tnord's Avatar
Default odd gearbox issue
so i took my new gsr over to a friends house who has a type-r so he could look over the car and tell me what problems i have. amongst the usual valve cover gasket, cam seals, oil pan gasket, i had been having problems shifting and getting an occasional grind on downshifts. specifically, especially when driving hard the gear lever just won't notch into gear. double clutching doesn't work, nor does rev-matching. sometimes it won't even go into 1st at a dead stop, but a blip of the throttle with light pressure to the lever will do the trick. driving around like your average joe schmo and it seems to be fine, get on it a bit, and it becomes a bugger.
first thing we did was drain out the old transmission oil to see if there was any brass (synchros) or other metal (gears) bits in there. nothing, although the oil was thin as water and black as night. so new honda MTF was added, which drastically improved shifting, and it hasn't grinded on me since. but i was still having the same problem.
next we checked to see if the slave cylinder was doing anything, because it's almost like the clutch isn't fully disengaging. slave seemed fine, and clutch fluid is full, so the lines aren't leaking anywhere.
after that was inspection of the motor mounts. my friend checked them, and said the one on the drivers side was fine, but one on the transmission was toast, and the other one was starting to go bad. would this be the root of the problem?
Old Aug 8, 2004 | 07:04 AM
ebelp's Avatar
Default Re: odd gearbox issue (tnord)
What is the condition of your clutch?
Old Aug 8, 2004 | 07:07 AM
tnord's Avatar
Default Re: odd gearbox issue (ebelp)
without cracking it open and looking, i say it's fine. it doesn't slip in any gear, maybe engages a little bit high, but nothing abnormal. also an acceptable amount of slop at the top.
Old Aug 8, 2004 | 10:39 AM
socalitr00's Avatar
In which gears is this a problem? Even though you didn't find anything in your gear oil it sounds like a worn synchro.
Old Aug 8, 2004 | 04:51 PM
tnord's Avatar
Default Re: odd gearbox issue (socalitr00)
all gears, even 5th is stubborn and won't go in sometimes. i can't see any reason for the 4th-5th synchro to be worn.
Old Aug 9, 2004 | 09:52 AM
BudMan's Avatar
Travis - I got 5$ that says you have a broken spring on the clutch plate.
Old Aug 9, 2004 | 12:57 PM
cheezthis's Avatar
Default Re: odd gearbox issue (BudMan)
My spring broke on my GSR...it completely popped out however, leaving me stranded basically.
It sounds very similar to your problem. Good luck!
Old Aug 9, 2004 | 01:52 PM
tnord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">Travis - I got 5$ that says you have a broken spring on the clutch plate.</TD></TR></TABLE>
i got a case of beer that says you can pull the clutch for me.
Old Aug 10, 2004 | 04:59 AM
BudMan's Avatar
wifey said okay - Sunday afternoon clutch install
Old Aug 10, 2004 | 05:24 AM
jDMJeRk's Avatar
if the MTF didnt do the trick with grinding; throw some Syncromesh FM in there... I had a REALLY bad grind in my y1 w/lsd and it took it away. It doesnt fix the problem but it sure will baby it for a while and make you *think* your tranny is good as new.
Good luck bro!
Schmitey
Oct 1, 2012 04:59 PM
delprad
Nov 21, 2007 11:10 AM
shawty123
Jul 4, 2007 11:14 AM
BB6racer
Jun 28, 2005 04:56 PM
pete332
Feb 20, 2004 10:50 PM
