Check Engine Light Question!
Old Apr 3, 2006 | 12:26 AM
xH22xTEGx's Avatar
Default Check Engine Light Question!
the car is a 94 teg with an h22a.
will the car throw a check engine light if the distributor is going bad or having problem? thanx
--brandon
EDIT: the reason im asking is because my distributor is making weird noises like the bearing in there is on the way out the door. The check engine light will only come on when i make a hard corner. It's idleing a lot lower than normal as well. I'm not sure if the hard corners and my distributor have any correlation but im sure somebody out there has some experience of something like this.. any help is appreciated, thanx
--brandon
Old Apr 3, 2006 | 04:09 AM
tegman85's Avatar
get the light to come on and take it somewhere with a scan tool, plus if its making weird noises id change it anyway
Old Apr 3, 2006 | 11:05 AM
xH22xTEGx's Avatar
yea im gonna change it out and get the codes checked.. just thought someone might have some experience with something like this.
Old Apr 3, 2006 | 11:43 AM
-Todd-'s Avatar
Default Re: (xH22xTEGx)
Can you not check the cels yourself?
Old Apr 3, 2006 | 01:03 PM
xH22xTEGx's Avatar
Default Re: (-Todd-)
Yes.
Old Apr 4, 2006 | 11:52 AM
xH22xTEGx's Avatar
i pulled the codes and it's a "1" code. Im thinking that's an o2 sensor but the chip that i have in the car (JDMSH1T p28 h22a chip) should delete that code from coming up (i think)... im not really sure whatsup any help would be appreciated.
Stephen122193
Jan 2, 2012 02:45 PM
Blue00Si
Nov 9, 2008 11:35 AM
0-400DC2-R
Sep 28, 2003 11:48 AM
BMacls
Mar 18, 2003 08:29 AM
