F22B in a integra???
Old Apr 5, 2006 | 09:49 AM
001020's Avatar
Default F22B in a integra???
can you put the prelude f22b in a dc integra..if so what tranny and mounts would you have 2 use??
Old Apr 5, 2006 | 10:20 AM
Tornadom's Avatar
Default Re: F22B in a integra??? (001020)
I believe an F motor is very similar to an H motor as far as mounts and size. If so, grab up any of the quality mount kits that swap the H22 into the Integra chassis. As far as transmission goes, I think the F and H transmissions interchange. You will need a transmission that will bolt up to the motor, I would go with an H22 transmission that has the factory equipped LSD.
Old Apr 5, 2006 | 01:30 PM
JETSPD1477's Avatar
Default Re: F22B in a integra??? (Tornadom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">I believe an F motor is very similar to an H motor as far as mounts and size. If so, grab up any of the quality mount kits that swap the H22 into the Integra chassis. As far as transmission goes, I think the F and H transmissions interchange. You will need a transmission that will bolt up to the motor, I would go with an H22 transmission that has the factory equipped LSD.</TD></TR></TABLE>
malerie
Feb 27, 2010 03:08 PM
solk1dd
Mar 8, 2005 07:37 AM
singlecamkilla
Mar 5, 2004 03:57 PM
