Lighting problem
Old Apr 6, 2006 | 08:46 AM
ir0nmanx's Avatar
Default Lighting problem
Ever since i got my car the passenger jdm side marker never worked and the turn signals stay on but never blink. Yesterday the passenger turn signal just stopped working. I have no experience in wiring and i dont want to mess anything up. Anyone have any ideas on how to fix this?
Old Apr 6, 2006 | 09:29 AM
gubenflaben's Avatar
Default Re: Lighting problem (ir0nmanxdc4)
have you tried changing the bulbs?
Old Apr 6, 2006 | 09:39 AM
ir0nmanx's Avatar
Default Re: Lighting problem (gubenflaben)
Ok, I got the turn signal and the side marker to work. Now I just need to know how to make the turn signals to blink. As of right now they just stay on and don't blink when i use it.
Modified by ir0nmanxdc4 at 4:30 PM 4/6/2006
Old Apr 6, 2006 | 03:30 PM
ir0nmanx's Avatar
anyone?
Old Apr 7, 2006 | 11:31 AM
2qwik2nv's Avatar
Now I'm not too fresh on electrical either, but have you tried changing all of the bulbs? There needs to be a certain resistance in the system. Also, the signal can, the thing you hear tick may be going. I'm not sure where it's located under the dash, a HELMS manual should help out, but that will be a fairly easy and cheap think to pickup and test.
Old Apr 7, 2006 | 03:58 PM
ir0nmanx's Avatar
Default Re: (2qwik2nv)
Yes, I have change the bulbs and they all light up perfect. Now I just need to fix the turn signals so that it blinks and not just stay on. I dont have a helms manual.
Old Apr 7, 2006 | 04:24 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
sounds like you need to replace the flasher. It's just a small relay-type unit somewhere under the dash (not sure where)... AutoZone should have a replacement.
Old Apr 7, 2006 | 04:26 PM
ir0nmanx's Avatar
Default Re: (PatrickGSR94)
I'll check that out, thanks for the input.
Farquea
11
Nov 14, 2021 12:24 PM
superfly23
Honda CR-V & Element
Feb 22, 2016 01:00 PM
Acethriller
Lighting
Jan 4, 2014 07:58 PM
thunderboy
Nov 7, 2007 12:01 PM
Uncle Ben's
Jul 8, 2007 12:08 PM
