cant read abs codes
Old Apr 5, 2006 | 11:39 AM
v-tec maz's Avatar
Default cant read abs codes
well when i try to read abs codes my abs light doesnt flash to me. my check engine light flashes and i can read the codes but the abs light just stays on. btw my car is a 97 and i belive i have a 2001 cluster
Old Apr 5, 2006 | 12:48 PM
v-tec maz's Avatar
Default Re: cant read abs codes (v-tec maz)
bump
Old Apr 5, 2006 | 02:13 PM
-Todd-'s Avatar
Possible causes for an ABS indicator light that does not go off, but no diagnostic trouble code is indicated...
blown rear defroster relay/heater motor relay/cooling fan motor relay (7.5A) fuse
open circuit between the under-dash fuse/relay box and ABS control unit
open circuit between the battery and under-hood ABS fuse/relay box
blown ABS B2 (15A) fuse
open circuit inside the under-hood ABS fuse/relay box
open circuit between the under-hood ABS fuse/relay box and ABS control unit
faulty alternator
open circuit between the alternator and ABS control unit
short to body ground in the warn circuit between the ABS indicator light and ABS control unit
faulty ABS control unit
That's what I got from my manual. I'm going through the same thing right now but still having trouble tracking the problem down.
Whatislove
Honda Civic (2001 - 2005)
Aug 29, 2009 08:35 PM
Solster
Jan 28, 2009 07:42 AM
cslegacy
Sep 11, 2007 03:36 AM
vti444
Sep 6, 2004 12:44 PM
ArchAngel Sabastian
Jan 20, 2003 04:49 PM
