Same as ITR chassis?
Old Apr 21, 2006 | 11:17 AM
Understeer's Avatar
Default Same as ITR chassis?
Are all 94-01 Integra's chassis the same as the ITR?
I'm setting my ride height and I've got some numbers from the center of the wheel hub to the fender on an ITR an wondering if there were any difference in body panels and such that would throw the numbers off?
Old Apr 21, 2006 | 11:59 AM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
Default Re: Same as ITR chassis? (Understeer)
The difference in body panels are only from the 97 front end to the 98+ front end. Other main differences are stiffer chassis and additional chassis rigdity bars, such as the performance bar in the trunk and the rear sway. But nothing as far as fenders or quarterpanels are any different.
Old Apr 21, 2006 | 12:21 PM
Understeer's Avatar
Default Re: Same as ITR chassis? (Usagi Yojimbo)
Thanks.
I already knew about bumpers, chassis stiffening improvment but if the panels are the same, then cool..
Old Apr 21, 2006 | 12:23 PM
projectTeG's Avatar
the ITR is a rs chassis with the seam welding and the added strength bars.
Old Apr 21, 2006 | 03:07 PM
LordAphotic's Avatar
i dont think the type r has seam welds.... thats expensive for a car company...
all the g3 integras share the same main chassis....
the reason the type r has a stiffer chassis is becuase of the parts placed on it. you could make any integra as stiff as the type r.
Old Apr 21, 2006 | 03:18 PM
projectTeG's Avatar
Default Re: (LordAphotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">i dont think the type r has seam welds.... thats expensive for a car company...
the reason the type r has a stiffer chassis is becuase of the parts placed on it. you could make any integra as stiff as the type r. </TD></TR></TABLE>
whoops i read somewhere it had them, oh well my bad
Old Apr 21, 2006 | 03:21 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (projectTeG)
The rear frame rails are thicker as well on the ITR.
Old Apr 21, 2006 | 03:23 PM
JETSPD1477's Avatar
dont forget the stickers...
Old Apr 21, 2006 | 03:26 PM
Dogginator's Avatar
Daisy... Daisy...
You would have to do much welding and part replacement to make a non ITR DC chassis as stiff as the ITR.
Old Apr 21, 2006 | 06:16 PM
sunnydeez's Avatar
my 99 ls will not accept a stock itr lower tie bar....???? i dunno........
Old Apr 21, 2006 | 07:24 PM
Naruto's Avatar
Default Re: (itrtguy01)
Here some mundane details for you The rear interior quarter panels are similar but not the same between the type R and other model integras. How do I know? I bought some type R ones and put them in my teg. At first, I thought the a55hole that sold them to me did some kinda custom work and cut out some of the plastic where it meets the rear seat. Turns out its supposed to be that way. I looked into a friend's type R and saw that where the bottom portion of the rear seats ( chassis I'm assuming ) sits.....it "sticks" out further on the side. My teg didn't have that
That and the rear panel in the trunk has some pre cut holes for the back bar that sits in the trunk of all itrs. Oh yea...that and my friend's type R did NOT have a map light. It did have the dome light though.. Aside from that...the other panels are similar.
Modified by Naruto at 9:41 PM 4/21/2006
Old Apr 21, 2006 | 07:29 PM
RedGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
This info is correct. All the body panels are the same, but there are lots of improvement on the chasis and the subframe.
As far as hand made goes, I know the B18C5 engines are hand made, not too sure about the chasis itself. I wouldn't be suprised if there are some welding done by people instead of machines specifically for the ITR. It was such a special vehicle for Honda and it wasn't high production, they could afford doing something different on it.
sengalang
Dec 23, 2010 09:18 PM
boricuatuning
Aug 26, 2009 10:48 AM
Chris F
Jun 22, 2006 10:51 AM
e2000
Oct 3, 2004 01:54 PM
vtecdoesabodygood
Dec 13, 2003 08:39 AM
