EF engine mounts in DA?
Old Apr 18, 2006 | 07:33 PM
mymeatb18
Default EF engine mounts in DA?
will my EF engine mounts work in a 90-91 DA?
thanks
Old Apr 19, 2006 | 05:16 PM
mymeatb18
Default Re: EF engine mounts in DA? (mymeatb18")
bump wanna know if i need to buy new polyurethane engine mounts before i do my swap
Old Apr 20, 2006 | 07:57 AM
mymeatb18
anybody?
Old Apr 20, 2006 | 09:24 AM
Wraith_G2IC's Avatar
I am fairly certain they won't. Any B-series engine you want to drop in a DA, you just use your stock DA mounts. If you are going 250+whp you may want to look into Innovative Mounts poly kits.
Old Apr 20, 2006 | 09:28 AM
mymeatb18
Default Re: EF engine mounts in DA? (Wraith_G2IC)
thanks somebody answered but i just want to be for sure so if anybody know for sure dont be skimp on the info
Old Apr 20, 2006 | 05:26 PM
mymeatb18
bump
Old Apr 20, 2006 | 07:16 PM
teggytegteg's Avatar
we're talking about a bseries motor mount from an ef right... well if so, yes it will fit 90-91 da's
Old Apr 21, 2006 | 01:02 PM
mymeatb18
Default Re: EF engine mounts in DA? (teggytegteg)
thank you very much it kinda sucks though cuz last night i ordered energy suspension inserts but they were only 20 buck so not that bad but ill probably use the inserts anyways since my mounts have seen much abuse for almost two years now
Old Apr 21, 2006 | 01:05 PM
ichbinsobose's Avatar
I want to see you fit EF mounts in a DA. Seeing how it's impossible and all. H-T is full of **** and misinofrmation.
Old Apr 21, 2006 | 05:39 PM
Default Re: (ichbinsobose)
if we are talkin about bseries driverside mount, yes it will fit 90-91 da...
my driverside mount was fucked and i left it till the stud and the screw on the bracket came off and snapped in half...i got the mounts and brackets from my donor 89 civic hatch that had a b16 swap.
please...dont contradict..
DarkSideHatch
Oct 25, 2009 10:03 AM
91EF_Si
Sep 6, 2007 08:01 PM
mymeatb18"
Apr 24, 2006 12:16 PM
BseriesHatch
Feb 27, 2004 01:25 PM
