engine knocking
Old Apr 20, 2006 | 09:28 AM
superrican's Avatar
Default engine knocking
Its a 95 gsr , It knocks when Started up and Slowly disappears at idle , THe knock isnt a CLick IT sounds like KNocking on a wooden table when Rev at 2,000......... Rod bearing? valve adjustments , where should i start
Old Apr 20, 2006 | 09:51 AM
DC2 Mang's Avatar
Default Re: engine knocking (superrican)
valves make a clicking sound
bearings make more of a sound like a crd in bike spokes
detonation sounds like someone hitting your blcok with a hammer
rod knock is a constan noise like someone taking a tiny jack hammer to the block
it could also be some random piece in your engine bay
my alarm horn was hitting against and wheel well, I was trippin out because I thought it was rod knock though
check timing abd listen for the bearing noise, if all else fail pull the oil pan off and inspect your block
amtrak23
Oct 27, 2015 07:49 AM
calvinkw1
Dec 7, 2005 11:06 PM
Toldge
Jun 23, 2005 03:28 PM
turboex
Aug 30, 2004 10:42 PM
jdm-spec-eg
Apr 1, 2003 02:31 PM
