code 65, car bogging
Old Apr 19, 2006 | 11:46 PM
b_serious's Avatar
Default code 65, car bogging
i have a b18b turbo in my ek and im getting code 65.. it had this problem for awhile but no when i go to use the car after a month of sitting it doesnt wanna accelerate at all.. well barely moves, im thinking its running in safe mode or somthing? anyone have any advice?
Old Apr 20, 2006 | 12:03 AM
b_serious's Avatar
Default Re: code 65, car bogging (b_serious)
sorry a little more clear, before it would be random.. i would unplug the ecu or battery to reset it and it would run fine.. then do it again about a week or so later.. it bogg's from 1-4.5k rpms after that it will climb normally.. but anything before that just bogs
Old Apr 20, 2006 | 05:44 AM
Danziver's Avatar
Code 65 is supposed to be the secondary oxygen sensor. What year is your engine? Sounds like symptoms of a bad o2 sensor hopefully its nothing more complicated than that.
Old Apr 20, 2006 | 11:37 AM
b_serious's Avatar
Default Re: code 65, car bogging (Danziver)
engine is a 98 in a 98 civic, when i jumped the socket the CEL flashed 6times slow then 5 times fast.. thats code 65 right? my downpipe only has 1 O2 hole where as my wiring harness has two sockets for 2 o2's
Old Apr 20, 2006 | 11:40 AM
Lan's Avatar
Lan
Yep 65. Check your cat too. The secondary could be fouling out if your cat is bad.
Old Apr 20, 2006 | 12:08 PM
b_serious's Avatar
Default Re: code 65, car bogging (Lan)
my exahust is strait back from the downpipe, no cat
Old Apr 20, 2006 | 12:21 PM
Lan's Avatar
Lan
Do you have a secondary or are you OBD1?
Old Apr 20, 2006 | 01:04 PM
b_serious's Avatar
i have a secondary but its not connected no hole for it in the manifold or downpipe
kaivorth
Honda Civic (2001 - 2005)
May 28, 2014 03:26 AM
YaBoiTHiZZ
12
Mar 28, 2012 08:10 PM
danteisme
Mar 16, 2005 07:01 AM
btrim23
Mar 14, 2005 08:01 AM
BigBoyJohn
Dec 26, 2003 11:35 AM
