need fpr fitting
Old Aug 7, 2006 | 04:53 PM
teddy_dc2's Avatar
Default need fpr fitting
the aem fpr wont fit with my edelbrock intake mani, i got a brass 90 degree elbow to run the line and works but the brass fitting is very loose so it leaks.
where can i get one with right thread pattern with 90 degree, can't extend more than 1/2" when fully on screwed to fpr or will hit intake mani. (tried hardware stores and they have jack, only one kinda thread pattern and standard sizes only)
Old Aug 8, 2006 | 12:32 PM
95 integra's Avatar
Default Re: need fpr fitting (teddy_dc2)
I believe the AEM uses a machine thread which should be available at lowes or somewhere like that. You could ofcourse always retap the hole or use some type of sealant to prevent the leaking.
Old Aug 8, 2006 | 01:46 PM
accordhybrid's Avatar
teflon tape
Old Aug 8, 2006 | 02:01 PM
95 integra's Avatar
Default Re: (accordhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid &raquo;</TD></TR><TR><TD CLASS="quote">teflon tape </TD></TR></TABLE>
Will be dissolved by gas and leak.
Old Aug 8, 2006 | 05:08 PM
JDMorgan's Avatar
you probably cross-threaded the fitting into the regulator. the threads on the fpr are -6 for an o-ring fitting. i never had a problem with using normal teflon on fuel fittings.
Old Aug 8, 2006 | 07:31 PM
teddy_dc2's Avatar
teflon gets really thin when contact with gasoline, wouldn't even matter if i put some there, i'll try thread lock. threads are fine, not stripped or anything, the only locking i get is when the fitting hits the washer and wont turn anymore, it drips.
Old Aug 9, 2006 | 04:15 AM
JDMorgan's Avatar
Default Re: (teddy_dc2)
y not just call aem and ask for the right adaptor? mine came with a banjo fitting so it aims 90 degrees, so i know they sell them.
Old Aug 9, 2006 | 06:09 PM
teddy_dc2's Avatar
Default Re: (KraZEtEggIE)
here is some pix:
tape measures 1/2" left of brass fitting while fully seated in fpr
install pix with very little room, need something like this but right threads
can i get a pix of yours?
Old Aug 9, 2006 | 06:35 PM
JDMorgan's Avatar
nevermind i didn't realize how tight of a fit it was. you need the adaptor that jackson racing sells. turns the fpr around 45 degrees.
nihad
Jan 4, 2010 01:45 PM
ctr83
Mar 3, 2008 04:19 PM
RTW DC2R
Jul 18, 2006 02:30 PM
fangtl
Jan 13, 2005 06:21 PM
EFb18b
Apr 23, 2004 06:06 AM
