IAB connection
Old Aug 7, 2006 | 04:38 PM
agy2k2's Avatar
Default IAB connection
Does anyone have a picture, or can get a picture of where the engine harness plugs into the IAB on a GSR?
Old Aug 7, 2006 | 04:48 PM
agy2k2's Avatar
or could you at least tell me where the connection is
Old Aug 7, 2006 | 04:53 PM
lVlemphizStylez's Avatar
Default Re: (agy2k2)
there is a box on the under side of the manifold, the connection is under there...it runs two wires from the plug, but i forget the color coding, one is a twelve volt source wire and the other is the ecu switch
Old Aug 7, 2006 | 04:58 PM
agy2k2's Avatar
hmm... i think that box is missing.
Old Aug 7, 2006 | 05:02 PM
then your IAB will not function
Old Aug 7, 2006 | 05:04 PM
agy2k2's Avatar
yes... i know that. i have a gsr to put in my civic, but when i was doing the harness i couldnt find the spot where that plug went... i think the guy took the IAB off
Old Aug 7, 2006 | 05:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agy2k2 &raquo;</TD></TR><TR><TD CLASS="quote">yes... i know that. i have a gsr to put in my civic, but when i was doing the harness i couldnt find the spot where that plug went... i think the guy took the IAB off</TD></TR></TABLE>
ok so this thread is pointless now...if you find the plug for the IAB it wont matter cause you dont have the box to plug it into...
Dogginator's Avatar
Daisy... Daisy...
Default Re: IAB connection (agy2k2)
Here is a picture. Hose 17 connects to the IAB actuator.
http://www.acuraparts247.com/p...ch=no
Old Aug 7, 2006 | 05:27 PM
agy2k2's Avatar
Default Re: IAB connection (Dogginator)
thank you, that is what i was looking for.
Old Aug 7, 2006 | 05:28 PM
agy2k2's Avatar
well since i didnt know whrer it went i didnt know it was missing. should i try to find one or should i get a different intake manifold??
Old Aug 7, 2006 | 06:39 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agy2k2 &raquo;</TD></TR><TR><TD CLASS="quote">well since i didnt know whrer it went i didnt know it was missing. should i try to find one or should i get a different intake manifold??</TD></TR></TABLE>
U will need it or else the secondary butteryflies will constantly stay open in the intake manifold, and it may or may not cause u idle or performance problems. With my swap it was disconnected for some time and I wondered why my car wouldnt idle right.
Anyways, when u wire it, send one wire to the ECU (i dunno which ecu u are running to tell u exactly which pin) and the other wire grounded to the intake manifold.
U can get another manifold, but then u would have to cancel out the IAB signal somehow and get LS or ITR throttle cable and bracket
Old Aug 7, 2006 | 08:04 PM
agy2k2's Avatar
will it throw a CEL if i dont have this hooked up?
Jaz760
Apr 24, 2009 10:16 AM
bmoney
Aug 13, 2006 01:36 PM
timmy0tool
Mar 28, 2006 11:09 AM
chitownrida
Oct 2, 2004 09:31 AM
Jonathan_ED3
Jun 21, 2003 04:16 PM
