how do i remove a b16 head?
Old Aug 7, 2006 | 08:59 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default how do i remove a b16 head?
i tried searching and didn't come up with anything..
if anyone has a diagram of the bolts that hold the head down to the block that would be great..
or some pics or info of where the bolts are
i need to see if my valves are bent from my timing belt snap..
bumps would be appriciated
Old Aug 8, 2006 | 05:08 AM
JDMorgan's Avatar
buy a hayes or helms manual. if you snapped your timing belt you probably did some serious damage. does the motor run? does it make any power?
Old Aug 8, 2006 | 09:17 AM
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">buy a hayes or helms manual. if you snapped your timing belt you probably did some serious damage. does the motor run? does it make any power?</TD></TR></TABLE>
i just wanna look to see how bad it is, i havn't put a new timing belt on yet. but when i wasn't aware of it being broken it didn't tick or knock or anything, so hopefully it isn't bad...
hayes or helms manual is a good idea, didn't think of that, i have a bunch at work. thanks alot
Old Mar 18, 2008 | 04:06 PM
dragonfly2k3's Avatar
Default Re: (ohsnapzafingcu)
bump up an old topic, im looking for a write-up as well. Also, if you snapped the timing belt the car didnt run at all, i promise haha. It may have skipped and still run?
raindance1280
Honda Civic (2001 - 2005)
Oct 23, 2008 10:46 AM
rwcdrums
Aug 26, 2008 03:35 PM
da_bseries
Aug 13, 2008 07:27 PM
ZXRider
Dec 31, 2006 04:07 PM
RacerZook
Jan 6, 2004 04:52 PM
