overheating
Old Aug 5, 2006 | 02:56 PM
95_red_dc's Avatar
Default overheating
Its 90' degrees out side and sometimes it starts to overheat. I have a b18b in my 91 crx s, I it never went in to the red area but it goes above normal. Then I will pull over stop shut the car off and let it sit for a couple mins and start it back up and it is in the same spot then I start to drive and it goes back down to normal and it wont over heat anymore for a while any one have anyidea wwhat the problem is thanks
Old Aug 5, 2006 | 03:42 PM
95_red_dc's Avatar
Default Re: overheating (ls_swaped_crx)
help
Old Aug 5, 2006 | 03:49 PM
b20integrapower's Avatar
it goes down when you drive? your thermostat may be stuck open.
95 integra's Avatar
add coolant It might help to have details like if it only does it in town, on the highway, etc. Is your fan kicking on?
Old Aug 5, 2006 | 03:59 PM
95_red_dc's Avatar
coolants full and fan runs all the time
Old Aug 5, 2006 | 04:05 PM
be more specific on your problem and i may be able to help you.
Old Aug 5, 2006 | 04:12 PM
95 integra's Avatar
Default Re: overheating (b20integrapower)
again, does it happen on the highway, city or both?
Old Aug 5, 2006 | 04:14 PM
95_red_dc's Avatar
sometimes overheat the coolant is full and the fan runs all the time it never gets in to the red area on the temp gauge but it gets close i shut it off and pull over let it sit and then i start it back up and it runs fine no overheating at all
Old Aug 5, 2006 | 04:50 PM
are u sure its just not the gauge? have you actually checked if the coolant is bubbling over into the resavour?
senorris08
Dec 6, 2007 05:03 PM
macrob68
Jun 15, 2006 04:16 AM
PureEF8
Jan 20, 2006 06:28 PM
petersayarath
Jun 16, 2005 04:59 PM
dawalude
Jul 23, 2004 11:41 PM
