Thar she blows
Old Aug 6, 2006 | 01:49 PM
diversegsr's Avatar
Default Thar she blows
decided it was time to check the compression and the spark plugs....plugs looking good and heres the compression check ( as a rem. this is a b18c1 with 90+miles on orginal engine...no rebuild and headgasket has never been replaced)
1:230
2:230
3:225
4:225
the comp numbers look good but kinda higher then the last time I check....I think last time I checked it was 205 across the board and this was maybe over a year ago......
is this the norm for higher milage cars
comments.....
Old Aug 6, 2006 | 01:53 PM
m3bluegsr's Avatar
Default Re: Thar she blows (diversegsr)
Those look fine.. i thought the rule was if they are within something like 5-10 percent it was healthy. i had a built c1 with 9.5 comp and mine were around 180.
Old Aug 6, 2006 | 02:20 PM
atg1290's Avatar
Yeah im pretty sure as long as there in the same area then its ok...I need to do a compression test on my 94 with 140k!
Old Aug 6, 2006 | 02:37 PM
Deluzional's Avatar
Default Re: (atg1290)
those comp #'s look really good, nothing to worry about
Old Aug 6, 2006 | 06:19 PM
phateless's Avatar
i read in a sportcompactcar magazine article once that carbon buildup on the valves/pistons can actually raise compression in a high mileage car. i'm not sure if i'll buy that, but what the hell, ya know? your car is in good shape, GSR motors will literally go 250k with no rebuilds, headgaskets, or any of that nonsense. all you gotta do is change the oil and keep up on maintenance. make SURE you get your timing belt done on time.
Old Aug 6, 2006 | 06:23 PM
Dogginator's Avatar
Daisy... Daisy...
You have a really good compression tester. The tester can significantly affect the readings. My cheap tester has about 2cc of volume before the one-way valve. So I typically read about 200 psig.
Old Aug 6, 2006 | 06:33 PM
ac_attak's Avatar
When your compression numbers were 205 across the board were you using the same tester as this time?
Your numbers are consistant which is the main thing anyway.
Old Aug 6, 2006 | 06:48 PM
enil01's Avatar
Default Re: (phateless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote">i read in a sportcompactcar magazine article once that carbon buildup on the valves/pistons can actually raise compression in a high mileage car. i'm not sure if i'll buy that, but what the hell, ya know?</TD></TR></TABLE>
True story. That's what I was going to suggest the carbon buildup decreases the size of your combustion chamber which puts more pressure on the same amount of air/fuel mixture. Thus you get higher compression readings.
Old Aug 6, 2006 | 08:06 PM
jared99's Avatar
Default Re: (enil01)
I chiseled what seemed like about a mm of carbon off my pistons when I swapped the head. Maybe I can do something to get a lot of carbon buildup so I can be running a hi-comp LS head
Old Aug 7, 2006 | 01:01 AM
phateless's Avatar
i've heard stories of thin head-gaskets to increase compression... that sounds like bullshit to me, but you never know...
Old Aug 7, 2006 | 05:58 AM
1point7db2's Avatar
Default Re: (jared99)
Tested the b17a1 in my car the other day, the #'s were 215,215, 210,205, The motor just turned 260k, and has never been rebuilt. Some of the gaskets leak a little, but it doesn't burn oil either.
Old Aug 7, 2006 | 06:02 AM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
Default Re: (1point7DA)
Every tester will give you diff results plus where your located, pressure etc. everybodys is alowys gonna be a little diff
Old Aug 7, 2006 | 09:00 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote">i've heard stories of thin head-gaskets to increase compression... that sounds like bullshit to me, but you never know...</TD></TR></TABLE>
This is equivalent to shaving the head. You can see the effect here.
http://www.c-speedracing.com/h...c.php
Old Aug 7, 2006 | 11:45 AM
diversegsr's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point7DA &raquo;</TD></TR><TR><TD CLASS="quote">Tested the b17a1 in my car the other day, the #'s were 215,215, 210,205, The motor just turned 260k, and has never been rebuilt. Some of the gaskets leak a little, but it doesn't burn oil either.</TD></TR></TABLE>
Old Aug 7, 2006 | 06:43 PM
enil01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jared99 &raquo;</TD></TR><TR><TD CLASS="quote">I chiseled what seemed like about a mm of carbon off my pistons when I swapped the head. Maybe I can do something to get a lot of carbon buildup so I can be running a hi-comp LS head </TD></TR></TABLE>
Run a couple tanks of diesel fuel through her...
Old Aug 7, 2006 | 06:52 PM
Nors's Avatar
LOL, the "stories" you heard are correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote">i read in a sportcompactcar magazine article once that carbon buildup on the valves/pistons can actually raise compression in a high mileage car. i'm not sure if i'll buy that, but what the hell, ya know? your car is in good shape, GSR motors will literally go 250k with no rebuilds, headgaskets, or any of that nonsense. all you gotta do is change the oil and keep up on maintenance. make SURE you get your timing belt done on time.</TD></TR></TABLE>
This is VERY true. 1 MM of carbon build up could change the compression a decent amount.
Old Aug 7, 2006 | 07:56 PM
phateless's Avatar
craziness... so romping on your car really is good for it. heh
diversegsr
12
Aug 6, 2006 04:09 PM
jagged4698
Sep 5, 2005 06:32 PM
Pandahatch
Aug 31, 2004 11:59 PM
siis2fast
Jun 16, 2003 11:09 AM
Phat Corolla
Aug 13, 2002 03:50 PM
