TYPE R HEADERS?
Old Aug 7, 2006 | 01:37 PM
jman86's Avatar
Default TYPE R HEADERS?
I know this has probably been answered a bunh of times but i cant find a yes/no answer. So here it goes....Im thinking about buying the dc sports headers prt #AHC6604 made for a TYPE-R i have a 96 LS in my car now..will those headers fit?...i want to buy them because i have a b20/vtec with a type r head that i am building and want to be able to use these later..
thanks
-jman
Old Aug 7, 2006 | 01:48 PM
94 EJ1's Avatar
Default Re: TYPE R HEADERS? (jman86)
any B series header will fit on a b series block. i have a B18A1 engine with an ITR 1peice header and it fit perfectly. so you shouldnt have a problem.
Old Aug 7, 2006 | 01:57 PM
jman86's Avatar
Default Re: TYPE R HEADERS? (jdm_2fast4u)
well...the header bolts to the head not to the block...so will it fit on the ls head and will it still be long/short enough to fit to the stock cat
Modified by jman86 at 3:13 PM 8/7/2006
Old Aug 7, 2006 | 02:01 PM
94 EJ1's Avatar
yeah because I have the LS head and it bolts on perfect its a little longer but nothing major it will fit your stock cat. its just a bitch to install because its once peice, you have to put the car on a hoist and install it under the engine but other than that you should be a go
Old Aug 7, 2006 | 03:13 PM
smooz EK's Avatar
this confuses me.
i was in the market for a carb legal header for my 2001 gs-r. i picked up a USDM ITR header for free so i was about the slap that on, but most people said not to waste your time because the USDM ITR header is almost the same shiet as the stock gsr header. then i came across a comp-tech header that came off a LS, but once i was about to make the purchase someone told me that it wont work on my car because it was a NON-vtech model. can someone help me clear this up?
Old Aug 7, 2006 | 03:36 PM
Padawan's Avatar
Darth ModerVader
USDM ITR, non-VTEC, and '00-'01 GS-R manifolds/headers are all interchangeable. Therefore, jman86, the Type-R header will bolt up to your car just fine, and smooze EK, the Comptech LS header will fit your GS-R with no problems.
Old Aug 7, 2006 | 03:51 PM
jman86's Avatar
Default Re: TYPE R HEADERS? (Padawan)
Thank you SIR....
Old Aug 7, 2006 | 04:06 PM
smooz EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">USDM ITR, non-VTEC, and '00-'01 GS-R manifolds/headers are all interchangeable. Therefore, jman86, the Type-R header will bolt up to your car just fine, and smooze EK, the Comptech LS header will fit your GS-R with no problems. </TD></TR></TABLE>
thanks.
but is there a difference in the design at all? for example, if i were to bolt up the NON-vtech comptech LS header to my 01 gsr will it perform just the same as a vtech comptech header?
Old Aug 7, 2006 | 06:16 PM
gsr dood's Avatar
Default Re: TYPE R HEADERS? (smooz EK)
sure the header will bolt up to the head. the problem is the lengths to the cat are diffrent throughout the year and models.
Old Aug 7, 2006 | 07:01 PM
Padawan's Avatar
Darth ModerVader
The part numbers for all 3 Comptech headers are the same.
Old Aug 7, 2006 | 07:24 PM
Padawan's Avatar
Darth ModerVader
Default Re: TYPE R HEADERS? (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">sure the header will bolt up to the head. the problem is the lengths to the cat are diffrent throughout the year and models. </TD></TR></TABLE>
As stated above, the only header out of all the different Integra models that is a different length is the '94-'99 GS-R. All the others are completely interchangeable.
yangd01234
Aug 2, 2009 12:47 PM
dungsta
Apr 29, 2005 10:38 PM
BIntegra99
Aug 1, 2003 01:44 PM
b18polo
Jul 3, 2003 05:51 AM
B16A1-EF9
Oct 13, 2001 06:00 AM
